rough idle/ intermittent hesitation
I have a stock 1992 civic LX.
Recently it started running poorly. It seemed like it was missing intermittently and idling rough after warming up.
It was overdue for new plugs. So I put in new NGK G-power plugs.
That helped significantly. It now drives smoother, but still with occasional hesitation. It still idles rough after warming up.
Since the new plugs helped, it makes me think perhaps the problem was weak spark and there's another problem (cap & rotor; wires; coil).
But it also reminds me of another car I had that had problems like this due to crud in the injectors, and would clear up after running Techron or similar injector cleaners through the fuel system.
It isn't throwing any codes.
Any thoughts about what to check next?
Yeah, I'd be willing to bet money that if you actually do a full tune-up, and not just a half-assed plug change, that your car will run better.
Lewsears
Mar 20, 2010 09:25 AM
JDM_SOHC
26
Jun 28, 2006 11:55 AM
07, 2008, civic, hesitating, hesitation, honda, idle, idles, intermittent, intermitton, low, missing, plugs, poorly, rough, running
