Help!! 98 civic ex Auto...
Old Dec 8, 2008 | 06:56 PM
MrMug3n's Avatar
Default Help!! 98 civic ex Auto...
My girlfreinds car is acting up! the car bogs to almost shut off and has no acceleration till you floor it and drives like sh*t. Not throwin any codes! Tranny gone bad? Tranny computer? Sensor?
Thanks in advance H.T.
Old Dec 8, 2008 | 08:40 PM
PowerUser's Avatar
check the spark plugs, wires, cap and rotor then get back to us.
Old Dec 8, 2008 | 11:09 PM
saywhat's Avatar
Also, when was the last time the transmission was serviced?
Old Dec 9, 2008 | 03:57 AM
MrMug3n's Avatar
Wires cap rotor are good so are the spark plugs any all grounds, I changed the tranny fluid 5months ago
Old Dec 9, 2008 | 05:48 PM
saywhat's Avatar
I guess check and make sure the intake isn't clogged with something, maybe fuel pressure issue? tough without any codes being thrown.
Old Dec 9, 2008 | 06:18 PM
Nic's Avatar
Nic
Just to ask....the check engine light does work right? When you turn the key on they engine does light up?
Old Dec 9, 2008 | 06:38 PM
dropped_dime98's Avatar
^thats a big mishap. My light went out till i finally relized the bulb was dead and found out i was throwing a code haha. Change your fuel filter see if that may help.
Old Dec 9, 2008 | 09:10 PM
Ruben19's Avatar
clogged catalytic convertor, dirty fuel filter.
Plug the obd2 tester to see if you have any codes
Old Dec 11, 2008 | 03:42 PM
MrMug3n's Avatar
Turns out that the crank sensor was rubbing against the altenator belt and was sending a poor signal. Not enough to send a code
AllOutBeard
Apr 26, 2017 06:45 PM
h_civ2000
35
Oct 20, 2009 04:15 PM
kaychi
Oct 14, 2009 10:06 AM
99blackdc2
Oct 28, 2006 08:40 PM
gemini05
May 25, 2006 07:41 PM
