Blowing Smoke???? (Its a little long sorry)
Old Aug 2, 2002 | 01:39 PM
SinisterCivic's Avatar
Default Blowing Smoke???? (Its a little long sorry)
I have a 2000 B18C5 in my 93 Civic H/B and im blowing smoke. I have I/H/E and VAFC on it. It didnt start smoking until i put the JDM 4 to 1 header from DC Sports. So at first i thought it was the header. But after a week that assumption was pretty much tossed out the window. Now the smoke is of a bluish tint which i know is supposed to mean smoke. So i checked my compression and it was perfect in all 4 cylinders at 135psi (well it was a little on the high side at 143psi) So i know its not my rings. So then what could it be. How would i be burning oil? Oh and the motor only as 14k miles on it. Any input would be greatly appreciated.
Old Aug 2, 2002 | 01:45 PM
98TypeR's Avatar
Default Re: Blowing Smoke???? (SinisterCivic)
your psi should be around the 180-220 mark. Some are even getting 240. Blue smoke means oil.
IT sounds to me like the rings. or head gasket.
[Modified by 98TypeR, 2:45 PM 8/2/2002]
Old Aug 2, 2002 | 01:52 PM
Default Re: Blowing Smoke???? (98TypeR)
Well i checked the local Acura dealership specs manual and it said 135psi plus or minus 28 psi so 107 low and 163 high and i also check the head gasket and its ok. so i still am not sure.
Old Aug 2, 2002 | 02:20 PM
01PYITR's Avatar
Just curious How did you check the head gasket?
Don't ya have to take the head off the motor to see the whole gasket???
Old Aug 2, 2002 | 02:47 PM
98TypeR's Avatar
Default Re: Blowing Smoke???? (01PYITR)
if you dont' believe me, check out some threads here.
https://honda-tech.com/zerothread?id=243051
https://honda-tech.com/zerothread?id=176578
https://honda-tech.com/zerothread?id=241411
https://honda-tech.com/zerothread?id=236655
https://honda-tech.com/zerothread?id=235120
btw, i have tested some old 91 si motors that were showing 130 across
PnoyGS-R
Nov 1, 2010 12:45 PM
j-bird20
Jan 11, 2007 05:59 PM
codyb13
Jun 16, 2005 08:47 AM
1SlowSi
May 20, 2005 10:01 AM
allm0torGSR
15
Jul 27, 2004 10:08 PM
