How much to fix a wheel bareing?
Old Aug 2, 2002 | 01:17 PM
Charlie Moua's Avatar
Default How much to fix a wheel bareing?
well i honda told me that it was gonna be $300 to fix the rear driver side wheel bearing. He said that's for parts and labor,.... does that seem high to you? how much does a bearing cost?
Old Aug 2, 2002 | 02:55 PM
Default Re: How much to fix a wheel bareing? (Charlie)
ttt
Old Aug 2, 2002 | 03:26 PM
Nick H's Avatar
New User
it's a honda dealer obviously, they are overcharging you by at least $75-$100 in this situation...
Old Aug 2, 2002 | 03:38 PM
ThightAccord's Avatar
Take it somewhere else...trust me
Old Aug 2, 2002 | 04:20 PM
Spooch69's Avatar
Default Re: How much to fix a wheel bareing? (ThightAccord)
We repaired my front right bareing. Cost about $50 for the bareing at autozone. Repair took about 3 1/2 hours. It was a pain because we had to take off the whole supension to get to the stupid bearing. I don't know how it is in the back wheel. Make sure if you do it, that you can get a machine to press the bareings out and back in. I think your local auto shop can do it.
[Modified by Spooch69, 7:52 PM 8/2/2002]
Old Aug 2, 2002 | 04:25 PM
Accord94DX's Avatar
which dealer quoted you that?
Old Aug 2, 2002 | 04:38 PM
GAccord's Avatar
Default Re: How much to fix a wheel bareing? (Accord94DX)
I need to replace my rear drivers side also.
Does your car make a loud humming noise at certain speeds?
Old Aug 2, 2002 | 05:06 PM
Spooch69's Avatar
Default Re: How much to fix a wheel bareing? (GAccord)
Yes, The reason why my bareing went out was because my brakes were sticking, and that made rotor very hot and that warped my rotor and burnt my bareings.
Old Aug 2, 2002 | 10:40 PM
91cordpos's Avatar
Default Re: How much to fix a wheel bareing? (Spooch69)
I don't know about the 5th gens, but on my 91 We had it changed out in a little over an hour if I remember correctly. The part ran about $100 also
Old Aug 4, 2002 | 10:43 AM
GAccord's Avatar
Default Re: How much to fix a wheel bareing? (91cordpos)
TTT, anyone else have any info. on this.
I might pick up the part and try and install it myself.
How difficult could it be? Tools needed?
I've installed struts/springs before, so I'm guessin it would be easier then that.
Old Aug 4, 2002 | 02:45 PM
Brookdale Honda, MN
Old Aug 5, 2002 | 08:06 AM
AcCoRdSi-R's Avatar
Brookdale Honda, MN
that is the most expensive place i have ever been to
Old Aug 5, 2002 | 09:58 AM
greensleeper's Avatar
Default Re: How much to fix a wheel bareing? (AcCoRdSi-R)
just bought front wheel bearings for my 95 - $37 each
http://www.hondaautomotiveparts.com
however I just looked and the bearings for the rear were 70 each. that for a 95 EX. and the labor looks a little more intense for the rears (you can see inthe diagram how many parts you have to get through until the the bearings comes out). What year accord are you talking about?
[Modified by greensleeper, 2:02 PM 8/5/2002]
Old Aug 5, 2002 | 10:31 AM
Spooch69's Avatar
Default Re: How much to fix a wheel bareing? (greensleeper)
We had to use a special tool to get the control arm off. I don't know what it was called, but it kind of looks like a mini pitch fork. Good luck
[Modified by Spooch69, 1:31 PM 8/5/2002]
Old Aug 5, 2002 | 10:59 AM
Gennady's Avatar
New User
Part: $60
Labor: $60
Time: 1 hour
Precedure: Remove brakes including rotors. Pull off spindle, and press out old bearing. Press in new bearing. Reassemble.
Hemix
10
Mar 5, 2007 06:12 PM
jax si
Sep 28, 2005 07:59 AM
g-ride-si
Sep 13, 2005 08:36 AM
Kowalski
Jan 31, 2005 11:52 AM
BrandonClaps
Jun 20, 2003 11:20 PM
