how hard is it to replace wheel bearing?
what is involveded? specialty tools ? i'm familiar with the suspension and eveything , but i have never changed one... i've checked everything else... do i need to replace the entire hub? will the same brake disc work? (not warped) ... thanks in advance for the info...
Re: how hard is it to replace wheel bearing? (jax si)
You dont have to replace the hub, unless if its the rare case of crazy honda that the hub breaks when its taken off (happens on 96-up civics).
But you need to send the knuckle off to a machine shop so they could use a press to pop it out and put it back in. You might be able to take the knuckle off and send it to honda to be replaced even.
Re: how hard is it to replace wheel bearing? (Luserkid)
well... i have a press at work... i'm in the military and we have one at our hangar.. so that's no problem... do you know how much it's gonna cost me for parts ? tia
HT Order of Merit
Wheel bearings are roughly 60$ each. I would get new dust sheilds too, since this is the only time you can replace them. Also, if you were ever considering extended wheel studs, nows the time! lol
Re: how hard is it to replace wheel bearing? (JDM_Ej)
Correct i replaced my wheel bearings then 3 months later i snapped 1 stud in each front hub and decided to put extended studs in when pressing out the hub the wheel bearings seperated and i had to buy brand new ones.
Re: how hard is it to replace wheel bearing? (SPOON_FED_DC_2)
haha funny you guys should mention this ... my front drivers side ... one of my studs are already broken... guess i should go ahead and take care of the problem.. thanks... nice to know some people on honda-tech aren't out to raise their post count , and actually help people.with things... i think i'm going to start an anti-post count crew... heh//.. thanks again/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">I would get new dust sheilds too, since this is the only time you can replace them.</TD></TR></TABLE>
Why would he have to replace the dust shields? I've replaced wheel studs and felt no need to replace the dust shield.
Re: how hard is it to replace wheel bearing? (Guam_CiviC619)
Because his replacing wheel bearings not just wheel studs. If you have the press do it yourself. Just remember theres a snap ring on each side of the bearing that you need to take out before you do it. Good luck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jax si »</TD></TR><TR><TD CLASS="quote">haha funny you guys should mention this ... my front drivers side ... one of my studs are already broken... guess i should go ahead and take care of the problem.. thanks... nice to know some people on honda-tech aren't out to raise their post count , and actually help people.with things... i think i'm going to start an anti-post count crew... heh//.. thanks again/</TD></TR></TABLE>
ketchup
17
06-27-2008 09:02 PM
pcorad
11-07-2001 04:55 PM
pcorad
11-07-2001 08:41 AM
