b16 into a ek chassis?
I got a full swap and i feel like such a noob because of these questions. Im taking a b16a swap out of a integra (dc) and putting it into my 96 ex, now i am using the axles, shiftlinkage. As far as mounts go can i use the dseries bracketing on the transmission side? The rear tbracket shoudl be from what? Lastly dont i need to change the engine mount to a 99-00 si l bracket?
cliffs:
what rear tbracket
99-00 si driver engine mount?
what transmission bracket do i use for the passenger motor motor mount on the frame rail.
cliffs:
what rear tbracket
99-00 rear civic Si T bracket
U can use ur 96 driver side mount but you need to change your bracket on the b16 to a 2 prong like the one on ur single cam.
Use a Bseries bracket on the transmition, it may have to be B16 (99-00) civic Si.
im not 100% sure which brackets you can reuse but i would just use b16a2(99-00)si brackets and use your stock mounts,,its what i did,but you may be able to combine your customize the 1's you have to work..i seen people redrill the rear t bracket and place the bolt through and i seen the drivers side mount used off a ek (stock)onto a b series ,,just extend the holes were the screw goes and use washers and long spacers,,or just buy si brackets,,,,,,your choice,,,,easy or save money,,,,i like saving
Yep.
Also true IIRC
You can reuse the original D-series upper transmission bracket.
KCHC
Aug 14, 2012 08:41 AM
deviant1
Mar 21, 2003 11:03 PM
