Changing spring lengths and weights in Tein SS
At the moment my Tein super streets (with upper mounts) still have the standard spring rates of 6k front/3k rear, wanting to change out the springs for 8k front/6k rear
At the moment the coilovers are wound right to the bottom of the threads all round, the free length of the springs are 250mm front/225mm rear
Would i be able to change the spring length for 225mm front/200mm rear with the new spring rates? Will be running the same height so it means i could just wind the spring seats up i guess?!
Thanks in advance for any input, they are fitted to my civic EK9 by the way
cool i see what you mean, since the rear springs are going to be a fair bit stiffer and with such little weight on the back it may be worth going down to a 200mm spring perhaps?
will have to jack the car up and measure the threads etc too see how much room i have etc for adjustment i guess!!
mr.sedan
Suspension & Brakes
Feb 24, 2006 09:06 PM
