Spring Rates?
Old Jan 21, 2002 | 09:52 AM
Big Dog's Avatar
New User
Default Spring Rates?
So what are the stock spring rates for the ITR? What length & rate are you using?
How much do they lower the car & do use any camber adjusters?
Old Jan 21, 2002 | 10:23 AM
Big Phat R's Avatar
Default Re: Spring Rates? (Big Dog)
Stock spring rates are
Front 243 lb/in (linear rate spring) which is equivalent to approx. 4.34 kg/mm
Rear 243 lb/in (progressive rate spring)
They use a progressive rate spring to soften daily driving. Also ride height in the rear is slightly higher to give the rear a higher CG. When the cars are new sometimes the front will be higher than the rear - but I think this is due to the differences in the way the linear vs progressive rate springs settle over time.
DA is best
Suspension & Brakes
Jul 7, 2007 11:15 PM
fg2si!kid
Honda Civic (2001 - 2005)
Nov 23, 2006 06:12 PM
bad-monkey
Aug 24, 2004 05:24 PM
austrian type-R
19
Nov 13, 2002 04:57 PM
Grimm
Jan 28, 2002 05:30 AM
