Im throwing a code 21.
Old Dec 7, 2008 | 07:51 PM
JdelMsolG's Avatar
Default Im throwing a code 21.
Vtec spool selenoid.
Are there any remedies to this without replacing the entire vtec selenoid?
I've tried two, throws code with both. Kinda starting to bother me since vtec isnt engaging.
any replies are appreciated.
Old Dec 7, 2008 | 08:25 PM
JdelMsolG's Avatar
noone?
Old Dec 7, 2008 | 09:06 PM
SOHC_4dr's Avatar
check oil level first. make sure its full. you may have a wiring issue. check the gounds
Old Dec 9, 2008 | 11:39 AM
JdelMsolG's Avatar
oil level is fine, grounds are fine.
Old Dec 9, 2008 | 11:58 AM
ifIexplode's Avatar
Have you tried cleaning the screen?
Old Dec 9, 2008 | 01:53 PM
JdelMsolG's Avatar
the screen is fine.
Old Dec 9, 2008 | 03:22 PM
Unseen Racer's Avatar
cleaning the screen??????
can some1 clerify this for me?
Old Dec 9, 2008 | 03:35 PM
DJackson1357's Avatar
There are two screens. One is between the block and the adapter plate (or whatever its actually called) and the other is between the plate and the solenoid. They can get clogged up.
To the OP, have you checked the oil pressure? I'm guessing the solenoid you have is actually good, did you run 12 V to it to see if it clicked? Did you check the resistance between a good ground and the pin on the solenoid? IIRC it should be between 15-30 ohms.
over_
Dec 2, 2006 03:55 PM
esca
Jan 1, 2005 08:46 AM
BobGnarly
May 23, 2004 05:28 PM
96tegsr
Aug 12, 2003 08:53 AM
toooslow
Jul 13, 2003 06:32 PM
