HELP!! P28 ECU ..Does it have VTEC?
Old Aug 2, 2002 | 09:08 AM
skunk2unerz's Avatar
Default HELP!! P28 ECU ..Does it have VTEC?
I need to know how I can tell that the ECU i bought is actually a p28 ECU from a 92 civic EX/Si w/ vtec. I know what a OBDI ecu looks like, but how can i tell is has VTEC. It doesnt have the sticker on the side that indicates is a p28 or are all 92-95 ECU p28? I just want to make sure i didnt buy a CX/DX/other
Old Aug 2, 2002 | 09:10 AM
714eg's Avatar
Default Re: HELP!! P28 ECU ..Does it have VTEC? (skunk2unerz)
Not full Vtec. Only B16, B18c, B18c5, H22 have full VTec.
Old Aug 2, 2002 | 09:13 AM
dohcsideSi's Avatar
Default Re: HELP!! P28 ECU ..Does it have VTEC? (714si)
take a pic of the board...
maybe i meant to say...does it have the VTEC sensor to kik start the VTEC solenoid on the enigine.. So is there any other way to tell I didnt just buy a CX/DX ECU?
Old Aug 2, 2002 | 09:22 AM
JDM_SiR_II_EG's Avatar
Check the serial bar....in the middle it will say P28....A02
Old Aug 2, 2002 | 09:23 AM
eg6ajk's Avatar
there is a second sticker on the plug side.
also VTEC ecus have VTEC transistors, which are not present on the p05/p06 ecu. other give away is the position of the MPU (which is only different from some P07 ecus)
Old Aug 2, 2002 | 09:25 AM
Default Re: HELP!! P28 ECU ..Does it have VTEC? (JDM_SiR_II_EG)
okay i just notice that serail #....it has p28 A01 So what is the 01 mean?
IS A02 VTEC?
Old Aug 2, 2002 | 09:31 AM
A01 might be automatic.....ive had two P28s from 5 speed 92 si....or maybe its newer....94-95? Not real sure, both mine said A02....even if its automatic it can be rechipped for manual I think...dont quote me on that one.
Old Aug 2, 2002 | 09:32 AM
eg6ajk's Avatar
37820 - honda ecu
P28 - civic si sohc vtec ecu
A01 / A02 / A00 different verisions of the board, or simply for different states, year - makes no difference (A = USA)
A51 = (A=USA, 5 = automatic ecu, 1 version)
C01 and so on (C= Canada)
Old Aug 2, 2002 | 09:33 AM
Default Re: HELP!! P28 ECU ..Does it have VTEC? (eg6ajk)
ahhh, the expert has explained...thnx man
Old Aug 2, 2002 | 09:37 AM
37820 - honda ecu
Thanks a BUNCH man- that helps out alot. for you!!
Old Aug 2, 2002 | 01:35 PM
hardcorehonda's Avatar
so wat would P28 G00 be?
i have 2 of them
Old Aug 2, 2002 | 01:44 PM
dogpile5's Avatar
25 Year Member
Default Re: HELP!! P28 ECU ..Does it have VTEC? (hardcorehonda)
nice diagram of a p28 ecu
(right click save )
shawnhayes's Avatar
Have a nice cup of STFU, unless you can back that up.
D15Z1, D16Z6, B17 from 92-93 Integra GSR, D16Y, D16Y8 all have VTEC. Unless you're talking about some bullcrap explanation that only makes DOHC's "full" VTEC, but then you STILL MISSED THE B17.
Real helpful.
Shawn
Old Aug 2, 2002 | 06:11 PM
RR98DX's Avatar
Default Re: HELP!! P28 ECU ..Does it have VTEC? (shawnhayes)
maybe FULL vtec to him means the ecu sends a little bit more VTEC to the motor, since all the VTEC comes from the ECU...right?! lol.
[Modified by RR98DX, 7:12 PM 8/2/2002]
Old Aug 2, 2002 | 06:13 PM
DragII's Avatar
25 Year Member
Default Re: HELP!! P28 ECU ..Does it have VTEC? (RR98DX)
LMAO!!!!
Old Aug 2, 2002 | 09:14 PM
Pho Real's Avatar
Default Re: HELP!! P28 ECU ..Does it have VTEC? (DragII-Sellout)
plug it up and pull it to 5200 dont drive around on it for long though .... you will run lean as hell .... but make sure of one thing hit "full VTEC" .... if not you will be missing half of VTEC ... meaning your VTEC is half full or.... half empty if your a negative person ... it all depends on how you look at it .... stay gold
[Modified by VTEXTC HB, 12:17 AM 8/3/2002]
Old Aug 10, 2010 | 08:06 AM
MyEGisBad's Avatar
I took off my oil pressure switch and nothing came out... does that mean my VTEC is empty????????????? Lmfao
Old Aug 10, 2010 | 08:16 AM
the hoove's Avatar
thats the funniest ish ive read in a long time. my p28 definetly gave me "full VTEC" you could really hear it once I got a new intake. Maybe it was only half full untill I got the intake. LMFAO!!!!
Old Aug 10, 2010 | 08:17 AM
Deetz's Avatar
Crazy Honda Guy
You bumped an "8" year old thread for that........~facepalm~
Old Mar 12, 2016 | 02:01 PM
aarhusjo's Avatar
I have a b18c1 and a fresh p28a1 ecu..wut else do i need?
Old Mar 12, 2016 | 03:16 PM
Former User's Avatar
You're quoting a 2002 post. Create your own thread in the Integra forum.
baulum
Engine Management and Tuning
Feb 16, 2020 08:48 PM
mpls
Feb 2, 2009 01:31 PM
simplypinoyy
Dec 9, 2004 07:15 AM
skunk2unerz
Aug 2, 2002 09:43 AM
