Went to the dealer and the weirdest thing happened...
Old Aug 2, 2002 | 07:23 AM
FD3S's Avatar
Default Went to the dealer and the weirdest thing happened...
I have eibach sportline springs and while on the stock rims and wheels i could notice that I had inner tire wear. It wasn't all that drastic or noticable. But then I got 17's with 205/40ZR-17 tires. I went to go get an alignment and the machine that they rolled my car over showed that my car was in perfect alignment. So I deleted the alignment of the job list. Has this happened to anyone else? Is it normal or possible? Or was is tech error and I should have it checked out again?
Old Aug 2, 2002 | 07:26 AM
DutchITR1689's Avatar
Default Re: Went to the dealer and the weirdest thing happened... (FD3S)
It's just neg camber. You can't adjust the camber with stock suspension.
Old Aug 2, 2002 | 07:27 AM
gblaue's Avatar
That's normal wear. Type R's have negative camber, which will cause inner edge wear.
Old Aug 2, 2002 | 07:47 AM
FD3S's Avatar
Default Re: Went to the dealer and the weirdest thing happened... (00ITR#756)
yeah but is it normal after being lowered?
Old Aug 2, 2002 | 07:49 AM
TsunamiZC's Avatar
you need a camber /caster kit...
Old Aug 2, 2002 | 08:06 AM
Dave-ROR's Avatar
As long as you have proper toe settings, you'll be good. BTW, why sportlines? lowering the car a lot to get worse handling than stock seems like a bad idea for some reason..
Old Aug 2, 2002 | 08:07 AM
Dave-ROR's Avatar
Default Re: Went to the dealer and the weirdest thing happened... (tsunami_zc)
no such thing for a DC2.
And you don't need a "camber kit" assuming are are at or less than 2 degrees neg camber or so.. maybe even a bit more.
Old Aug 2, 2002 | 08:26 AM
FD3S's Avatar
Default Re: Went to the dealer and the weirdest thing happened... (SoFreshAndSoCleanClean)
the readings on the machine were 0 and 0 that was the range. the sportlines have an awesome ride and eliminate the wheel gap with the 17's
SoFreshAndSoCleanClean<------BTW FC3S's are tight!
[Modified by FD3S, 9:27 AM 8/2/2002]
Old Aug 2, 2002 | 09:08 AM
Dave-ROR's Avatar
Maybe, but the sportlines aren't really my opinion of a performance spring.. just my opinion.
I've owned two of them before, the new project one is a friends, the process will be documented but we are shooting for 11s for < $4500 including the price of the car.. luckily we can do a LOT of the fabrication ourselves and all the work ourselves.
FD's are bad *** cars though.. love them.. but instead of getting one in a bit (after I pay off all my debt) I think I'll get a 93-95 MR2 Turbo instead.. I've always loved those things..
Old Aug 2, 2002 | 09:46 AM
MK Ultra's Avatar
0.0 deg toe.
-1.6 and -1.9 deg camber.
Insides of my AVSi's showing steel in 10 months.
I was a bit perplexed by this, as my first set of AVSi's lasted two years with very little inside wear with the same alignment specs. The second set got chewed up like Big League. The only thing I can think of is that all the long highway trips I was taking (500 miles every almost weekend for the last year) is what did it.
Old Aug 2, 2002 | 10:07 AM
Dave-ROR's Avatar
Default Re: Went to the dealer and the weirdest thing happened... (MK Ultra)
0.0 deg toe.
air pressure?
Old Aug 2, 2002 | 10:13 AM
MK Ultra's Avatar
32 psi, checked every other fillup.
Old Aug 2, 2002 | 10:16 AM
Dave-ROR's Avatar
hmm very interesting. Not sure what caused your issue. I've driven on highway and city (about 50/50 each) with -2.0 and -1.8 (fronts) and -1.5/-1.4 (rear) on tires for years now with absolutely no abnormal wear.. on P700-Z's, S03s and RE71s..
Old Aug 2, 2002 | 10:21 AM
MK Ultra's Avatar
That is interesting. After my first set of AVSi's lasted so long I thought that would be my case too. I used to make fun of my friends who bitched about their squeaking camber kits, thinking "I'll never need to mess with that."
A couple of weeks ago I had my knuckles bent to adjust my camber. I'm now running +.6 and +.7. Ack! Not what I wanted, and I'll have them redone soon. Interestingly enough, the cornering isn't that bad with the positive front camber, but the front end feels disconnected on the freeway.
blkcivic310
11
Mar 11, 2010 03:57 PM
steveharrmr23
Sep 9, 2008 12:10 PM
justininhifi
Jun 27, 2003 10:46 PM
Ludeboi
Apr 25, 2003 11:26 PM
kikkoboyie
Sep 17, 2001 04:26 AM
