lowered with no alignment?
Old Sep 16, 2001 | 09:21 PM
kikkoboyie's Avatar
New User
Default lowered with no alignment?
my cars lowered on eibach pro-kits.... i lowered it about 4 months ago, still havent gotten an alignment....
tire wear seems normal..... am i ok?
Old Sep 16, 2001 | 09:35 PM
X2BOARD's Avatar
Default Re: lowered with no alignment? (kikkoboyie)
How much have you lowered it ? Yes, you should get an alignment... See how much your Camber has changed, and to a less extent, your Toe.....
The possibility of negative camber is the real cause of premature wear on the inside... you might not notice in 4 months if you haven't lowered much (less than 2").... you'll prolly see noticable wear by 5-6 months.
Toe can be corrected to some extent with an alignment, but it is not as important as camber.... Some neg. camber is good for cornering, but too much will kill your tires anywhere from 4-16 months. (Depending on how much U R lowered).
Sorry about babbling.... it's late, I'm bored & blitzed......
Old Sep 17, 2001 | 04:26 AM
keithv's Avatar
You should always get an alignment after lowering the car, but you probably know this.
I dropped my Teg with the pro-kits and the camber was within spec. The toe needed to be adjusted, though.
JdmB16Eg6
Suspension & Brakes
Mar 28, 2006 10:29 AM
vdub08
Suspension & Brakes
19
Sep 3, 2005 01:14 PM
TypeR II
Suspension & Brakes
Jun 3, 2005 02:21 PM
tekstyle
20
Oct 29, 2004 09:12 PM
spork sport
19
Mar 12, 2002 09:02 PM
