Raising the revlimiter
I want to raise my revlimiter about 500rpm. What is the best way to do this? Also, I want a spark-inhibited revlimiter not the factory fuel cut-off...something besides an aftermarket ignition
[Modified by maztur, 10:12 AM 8/2/2002]
a chip. thats about the only way to do this since it is all computer controlled. www.hondata.com
I think the only way you can get a spark-inhibited revlimiter would be with an after market ignition like msd soft touch rev control. I wish they came with that instead of a fuel cutoff but I guess it would be bad for emissions so they don't.
I only want 500rpm because I still got stock valvesprings on the D16y8. I am running turbo so I THINK that a little higher revlimit can give me more power. I also want to stay in the powerband better.
I actually have a VAFC, and I have it set so that I am still in VTEC when I shift. However, I feel that the turbo should help me moreso on the topend (duh); therefore, raising the revlimit.
I have a D16Y8 with an ITR ECU. I can rev to 8,500 RPM but have only taken it to 8,000. If you're just adding a 500 rev limit, it's only even worth getting it chipped.
To answer your question, YES it is worth the hook up. Have some fun before your motor swap. You'll feel a big difference in the fuel maps(higher redline too). I raced my friend's EG wth a B16A the other day and stuck on him like glue, he only won by a car after third gear.
I also had a friend with a 94' Si with a GSR ecu, he was never able to chirp on third but after the ecu hook up he can. So hook it up and have some fun.
Won't cause any damage unless you take it past redline all the time.
I have a D16z6, what Ecu can i swap in. Why would this be a good idea what are the gains what will happen with the VTEC change over point
hondacummins
Engine Management and Tuning
12
Jul 20, 2014 08:14 PM
ebp_dc2
Jun 20, 2005 09:17 AM
hi-Powered
May 16, 2005 09:56 PM
