OK so i want spark cut not fuel cut at rev limit for nitrous...how can i do that??
Any way other than a new ignition or ECU...anything cheap? Reason i want this is obvious, but for those of you who don't understand i dont want to detonate if i rev limit bounce when spraying nitrous. Help me out guys
Thanks
Thanks
Re: (h22d dc2)
Get a MSD window switch, you can program it to spray during a set RPM range...won't spray before or after the set points. Thus if you miss-shift and hit like 10k, you won't also be spraying at the same time.
MSD Digital window switch. #8969.
