Raising the revlimiter
I want to raise my revlimiter about 500rpm. What is the best way to do this? Also, I want a spark-inhibited revlimiter not the factory fuel cut-off...something besides an aftermarket ignition
[Modified by maztur, 10:12 AM 8/2/2002]
Re: Raising the revlimiter (maztur)
a chip. thats about the only way to do this since it is all computer controlled. www.hondata.com
Re: Raising the revlimiter (714si)
Your not gonna make that much more power in the powerband by raising 500 rpm go like 9,000 depending on your set up!
New User
Re: Raising the revlimiter (dohcsideSi)
I think the only way you can get a spark-inhibited revlimiter would be with an after market ignition like msd soft touch rev control. I wish they came with that instead of a fuel cutoff but I guess it would be bad for emissions so they don't.
I only want 500rpm because I still got stock valvesprings on the D16y8. I am running turbo so I THINK that a little higher revlimit can give me more power. I also want to stay in the powerband better.
it wont help you
you make no power above the stock rev limit
its there for a reason.
upgrade your cam/spring setup then go for revving.
Re: Raising the revlimiter (95CivicEX)
I actually have a VAFC, and I have it set so that I am still in VTEC when I shift. However, I feel that the turbo should help me moreso on the topend (duh); therefore, raising the revlimit.
Sushi Buffet Champion
Re: Raising the revlimiter (dirtySOHC's)
I have a D16Y8 with an ITR ECU. I can rev to 8,500 RPM but have only taken it to 8,000. If you're just adding a 500 rev limit, it's only even worth getting it chipped.
Re: Raising the revlimiter (GapxGuy)
To answer your question, YES it is worth the hook up. Have some fun before your motor swap. You'll feel a big difference in the fuel maps(higher redline too). I raced my friend's EG wth a B16A the other day and stuck on him like glue, he only won by a car after third gear.
I also had a friend with a 94' Si with a GSR ecu, he was never able to chirp on third but after the ecu hook up he can. So hook it up and have some fun.
what kinda ECU swap can I make for a d16y7(dx)?? are there any I can get pretty cheap? I just want a little better fuel mapping.
please help sounds like an easy mod
Won't cause any damage unless you take it past redline all the time.
I have a D16z6, what Ecu can i swap in. Why would this be a good idea what are the gains what will happen with the VTEC change over point
Re: Raising the revlimiter (gavhowe)
hondacummins
Engine Management and Tuning
12
07-20-2014 08:14 PM
ebp_dc2
06-20-2005 09:17 AM
hi-Powered
05-16-2005 09:56 PM
