gsr head problems
Old Dec 4, 2008 | 06:16 PM
lcsej1's Avatar
Default gsr head problems
hey guys i'm really frustrated because i just got my swap from a friend and the only problem it had was a broken camshaft holder,the one besides the vtec solenoid. He said it happened when he was jacking the car. I had the holder laying around from my past gsr... so i replaced it. Torqued everything withing specs according to the manual. But my teacher at UTI said that what i did was totally wrong. He said that the head is junk unless i balance the whole camshaft assembly because the wear patter of the holder is different since it directly touches the camshaft. so what do you guys think about this?
Old Dec 4, 2008 | 06:53 PM
94EG8's Avatar
Seagull Management
Yeah, thats the theory anyway. I have done it before on a DOHC ZC (used a cam cap off a B18A1 so we could get a D15B7 distributor to bolt up) but I think I only ran it that way for about a week until we found a ZC distributor. It'll work, for how long is the question.
Old Dec 4, 2008 | 08:18 PM
rsnupt82's Avatar
in theory thats right.... i'd listen to your teach.
Old Dec 4, 2008 | 08:32 PM
96-EJ6 B18C's Avatar
You don't buy a new head or cam caps when your installing aftermarket cams do you???
Just check the oil clearance with plastigauge and make sure it's within spec, if it is it will be fine.
Old Dec 5, 2008 | 03:06 AM
lcsej1's Avatar
ok as of now i ddecided i will sell the swap for a reasonable price. 1400.... i'm so screwd guys i donno what to say!
Old Dec 5, 2008 | 12:28 PM
GSR936's Avatar
what the lowest on the tranny or bottom end ?
Old Dec 5, 2008 | 12:29 PM
lcsej1's Avatar
what you mean whats the lowest? it has 80k miles overall
Old Dec 5, 2008 | 01:33 PM
94EG8's Avatar
Seagull Management
This isn't quite the same. The cap is from one engine, the rest of the head from another. They both form what should be a perfect circle, however if the cap wore differently than the head, or if they were machined slightly differently you will have problems.
Old Dec 5, 2008 | 02:02 PM
GSR936's Avatar
i meant how much
Old Dec 5, 2008 | 02:06 PM
I agree, that's why he needs to check the oil clearence. If that is in spec and the cam spins it will be absolutely fine.
Old Dec 5, 2008 | 02:54 PM
lcsej1's Avatar
is it the journal oil clearance you guys are talking about?
Old Dec 8, 2008 | 07:13 PM
lcsej1's Avatar
just checked everything with plasttigage and its all under specs! so i should be goood!
mrsteezy123
Engine Machining & Assembly
May 20, 2018 09:40 AM
Lanolin18
23
Feb 15, 2009 07:20 AM
b18sihatch
Mar 20, 2007 01:31 PM
xxxmikenicexxx
Jul 31, 2005 07:17 PM
KLN
Apr 26, 2002 07:08 AM
