Vibrations after 60
Old Dec 4, 2008 | 02:37 PM
Marks EX's Avatar
Default Vibrations after 60
I got a 00 si and everytime im on the highway i get vibration in my steering wheel after 60 and higher. i just got new tires so im pretty sure its not that. any thoughts of what it would be? thanks
Old Dec 4, 2008 | 02:39 PM
andoxviii's Avatar
Go get them balanced.
Old Dec 4, 2008 | 02:46 PM
Brick Top's Avatar
were the vibrations going on before the new tires?
Old Dec 4, 2008 | 02:48 PM
punkinbeck's Avatar
its probably alignment or tires
Old Dec 4, 2008 | 03:08 PM
enycesam's Avatar
Balanced correctly?
Old Dec 4, 2008 | 05:01 PM
mauroalvarez@yahoo.com's Avatar
balance them. i have an 00 Si also. sittin on17's and it happens the same. get them correctly balanced and if u have dropped ur car 2"+ u have to get an alignment
Old Dec 4, 2008 | 05:04 PM
96civic_hb's Avatar
Agree as above. Get them balanced and possibly an alignment.
Old Dec 4, 2008 | 05:08 PM
IhateworkingoncaRs's Avatar
Chances are your tires were not properly balanced. Unless it's been awhile and your tires are starting to wear irregularly due to bad alignment and now they're out of balance. Just so everyone knows, alignments don't cause vibrations, they cause irregular tire wear which causes vibrations. Also, it might be drivetrain vibration; drivetrain vibration will change as you give it gas, hold gas steady or let of the gas. If it don't change then it's tire balance problem.
Old Dec 4, 2008 | 05:11 PM
Rheg6's Avatar
alignment doesnt cause steering wheel shake do not listen to anyone telling u it is an alignment. alignment only effects tire wear it may be a balance issue or check your front end parts
Old Dec 4, 2008 | 10:13 PM
slimjimming6688's Avatar
maby the drive shaft is missing the dampener
90daXsi
Sep 21, 2008 04:53 PM
94CDMeg
Sep 4, 2008 08:49 PM
dogbiscuit
39
Oct 1, 2005 05:19 AM
neopheus
Suspension & Brakes
Mar 17, 2005 08:02 PM
GapxGuy
22
Jun 12, 2004 03:16 PM
