Rod knock at engine start but goes away in a sec
H23A1 (202k miles) - I hear rod knock when I start the engine but it goes away in a sec or less. Is it safe to drive this car? Any easy fixes or do I have to drop the pan and replace the bearings assuming the journals are not gone?
Just my 2cents. Goodluck
I agree. Seeing as you have some miles on that motor, your rings are wearing and there is a gap between the cylinder and piston. When the pistons warm up, they expand and the noise goes away. Are you running 5-30W?
205
195
205
195
With no sparkplug wires connected. So not sure if rings are it. I know I'm gonna need to take it apart at some point but was wondering if there's any additive to put in that will take care of it temporarily?
Also, are those compression numbers ok?
Car runs fine and fast. It does sound like the oil picks up and fills the gap between the rod bearings and thats why the noise goes away. Compression test gave these numbers:
205
195
205
195
205
195
205
195
Only a leakdown will tell you for sure.
