Header ground clearance WTF!!
I have a jdm b16a2 in my eg hatch. I borrowed my boy's tri-y header and the ground clearance is absolutely ridiculous. this bastard scrapes on everything!! I have my car pretty low but generally drive with it really low. What would be a nice looking aftermarket header with the BEST ground clearance. Thanks for the input!
your boys tri-y header is probably for a b18 which is a little bit taller, which would make the header lower to the ground on a b16.
some that are designed for both are still good with ground clearance. i recommend DC.
his header is a b16 header, the bitch just sits so low and what makes it worse is that it angles down as it gets closer to the collector. Ghey! now I need to find a DC or something that isnt ***** expensive.
^^Talk about it, my 4-1 got smashed up on a man hole un a unfinished road at 35mph. Hit so hard it ripped the stainless steel header apart at the bend to the cat and ripped it off the block at cylinder # 3 & 4!!!!!
