Turbo not spinning freely
Old Dec 3, 2008 | 04:02 PM
romoracing's Avatar
Default Turbo not spinning freely
Well like the title says the turbo does not spin freely. i bought the 15g turbo used from someone and they said it work perfectly. He also said it sat for months. There is no shaft play at all(front to back, side to side)but when i try to spin the compressor it wont let me with out some force. After it gets started it spins for about two to three turns but then it sticks again. Today is the first time i ran oil thru. the turbo(custom kit)so I thought i was that it did not have any lube. but it still does it. I did not start the car cause i dont got my chips for my ecu. I thought that maybe during shipping it maybe got knocked around and the turbo balancing got out of whack. Would balancing the turbo fix this problem and I did search many times.
Old Dec 3, 2008 | 04:04 PM
b20beast83's Avatar
bearings seized is my guess
Old Dec 3, 2008 | 05:56 PM
romoracing's Avatar
So im guessing rebuild? or run hot oil through the turbo getting it lubed up? Maybe break down old oil.
btw. I forgot to mention when I get it to spin it does seem that the compresser is rubbing up on the housing.
Anyone else?
Old Dec 3, 2008 | 05:59 PM
TheShodan's Avatar
Moderator
Most oil-cooled turbos spin only about 2-4 times anyway. The more you try to spin it dry without lubrication, the worse you'll make the turbocharger.
Old Dec 3, 2008 | 06:10 PM
romoracing's Avatar
oh thank you man very much. That I didnt know. Ill stop till i get it started.
igo4bmx
Mar 27, 2005 08:47 AM
kj98r
May 16, 2004 03:16 PM
boostismycrack
Mar 4, 2004 07:04 PM
Teluan
Aug 27, 2001 05:32 AM
