Vtec stuttering
Old Dec 3, 2008 | 03:44 PM
BLU CIVIC's Avatar
Track Advocate
Default Vtec stuttering
swapped a B16b in about a month ago and no problems with vtec...changed my oil about 2 weeks ago and started noticing vtec stutter when engaged...from 6k to 8.5k rpm it goes stutters then goes...i though i may have an oil leak and there is no oil coming from anywhere that i can see...i saw this b/c i took a turn really fast that the oil light lit up...i check the dip stick and it shows no oil
not understanding what's going on...i'm thinking about going to put another quart in but any suggestions before i do this? i only say this b/c i blew my last engine engine b/c of too much oil (oil pick-up was bent)
Old Dec 3, 2008 | 05:17 PM
HOODLOVER's Avatar
fix that.
Old Dec 3, 2008 | 08:53 PM
SOHC_4dr's Avatar
VTEC needs oil to operate(along with other things) but if your low on oil, fill it back up. it'll work fine then.
Old Dec 3, 2008 | 08:58 PM
91DBSexyTime's Avatar
are you sure the filter is on tight enough and its not burning off the block? my B16 always leaked at the cam seals but I never had a problem with low oil or the v tec engaging..
Old Dec 4, 2008 | 04:09 AM
BLU CIVIC's Avatar
Track Advocate
looked under the car and there was no oil anywhere...but i will check the filter
Old Dec 4, 2008 | 04:32 AM
Furyof4's Avatar
The oil has to go somewhere. Your either leaking it or burning it. If you've been driving around in vtec with hardly any oil you already did damage.
Old Dec 4, 2008 | 04:41 AM
BLU CIVIC's Avatar
Track Advocate
I'm usually only in vtec when getting on the highway...other than that i drive like a granny...i'm going to get a compression check and going to drain the oil to see how many quarts i have...there are no tell-tell signs of burning oil so i don get it
but i put a quart in last night and today there were no problems...but if i was that low then my oil light or cel should have came on
FrontwheelENT
14
Aug 20, 2012 05:30 AM
B18C-YA!
28
May 2, 2006 10:52 AM
hondaracing1
Mar 17, 2004 06:47 AM
ludelvr
Nov 26, 2003 02:58 PM
