a little help!!
Old Aug 1, 2002 | 06:36 PM
hoya_10fintec's Avatar
Default a little help!!
ok... my english isn't good enough to explain what i'm experiencing with my ride...
anywayz, here goes nothing...
after i got a swap done in my car, it was running just fine 'til about a month ago...
it feels like it loses and gains HP back to normal everytime i start the car...
i mean, the power loss of the engine changes everyday and every ON/OFF of ignition...
eg.)first start, it runs and pulls good but at second start, it does'n run as good...(it changes everytime... )
but no codes or nothing... but one thing i found is that when my car's idling, it always idles at 900RPM... but when i rev to 1500RPM and let go of the gas peddle,
it all of a sudden drops to 700RPM and back to 900RPM... i tried adjusting idle w/ no luck... no matter which way i turn, it stays at 900RPM...
could this be the ignition problem?? bad connection somewhere under the hood??
vacuum leak?? this is making me nervous and mad!! so i'm here to beg u guys for help!! thanks for reading... be safe guys!!
[Modified by hoya_10fintec, 3:38 AM 8/2/2002]
Old Aug 1, 2002 | 06:39 PM
DragII's Avatar
25 Year Member
Default Re: a little help!! (hoya_10fintec)
ignition, vaccum, and fuel....
give each a once over, and do any scheduled maintanence that you may have overlooked.
Old Aug 1, 2002 | 06:45 PM
Default Re: a little help!! (DragII-Sellout)
vacuum leak.... how do i check for a vacuum leak?? ...and thanks...
Old Aug 1, 2002 | 07:55 PM
any more possibilities? or anyone with similar problems?? thanks...
Old Aug 1, 2002 | 10:25 PM
please!!!
Old Aug 1, 2002 | 10:35 PM
DOHCtorTHRUST's Avatar
i have the exact same set up as you do, except for the LSD and mines is a hatch...i get the same problem with the idling but the power seems to be the same eveytime i punch it... it could be the temperature of the motor at the time...i have a integ radiator and that mess is hella COOL after i punch it or when im sitting in traffic....maybe thats the problem... hope this helps....
Old Aug 2, 2002 | 08:38 AM
Default Re: a little help!! (DOHCtorTHRUST)
hmm.... possible... thanks,man.. .i'll check into that...
Old Aug 2, 2002 | 08:57 AM
deepnite's Avatar
did u have the ecu reset lately, dirty fuel lines..fuel pump..see what kinda shape ur plugs are in..hmmmmm? *anything else?* since it ran fine at one time something sounds like something needs replacing or maintenace...if all fails get a full diagnositic to find the problem..runs $80 at my neighborhood speedylube
Old Aug 2, 2002 | 10:43 AM
EKB18BPR3's Avatar
i say fuel pressure reg.
Old Aug 2, 2002 | 05:59 PM
Default Re: a little help!! (dniedacess)
thanks guys!! i guess i'll try everything that you guys told me... ma best bet...
Old Aug 2, 2002 | 06:40 PM
CunninLynguist's Avatar
when mine would bog it was due to a going back ignishion coil
OrangeBoost
Aug 1, 2006 05:13 AM
Rex_Ryder
11
Apr 1, 2005 02:48 PM
Vinhtran17
Jul 16, 2004 11:06 AM
dubracr18t
Aug 25, 2003 08:08 AM
