Internals
Old Nov 30, 2008 | 07:47 PM
mdoubleg's Avatar
Default Internals
I was wondering if i could get a few opinions about what should be done and what kind of stuff should be replaced to run high boost on a b18c1.
Old Nov 30, 2008 | 08:07 PM
weavertime1's Avatar
That all depends on what you consider "high boost." Most people would replace the pistons with a lower compression type, and replace the rods as well. Using head studs instead of bolts is always a good idea, and you may want to upgrade the head while you have everything apart. Upgrading the valvetrain will not usually make your car any more or less reliable (at stock rpms), although there is room for performance enhancement through valve train improvements (ability to take in and expell more air, as well as rev higher, etc.). I am sure many people will have ideas, but this is a start. Good luck!
Old Dec 1, 2008 | 10:16 PM
mdoubleg's Avatar
Hey thanks for replying, i'm still new to all this but i love it so i'm just trying to learn as much as possible. I notice tho when i look at rods there are like 3 different ones for the same engine. Does it matter on which ones i get or will either and any of them work?
Bonestock98GS
Sep 1, 2009 08:14 PM
ljs88
Jul 15, 2007 01:14 PM
DutchEG6
Aug 20, 2005 06:29 AM
deemack79
Feb 14, 2005 05:33 PM
StupidSlowRSX
Dec 13, 2003 11:06 AM
