Compression Question
Old Aug 31, 2009 | 07:37 PM
Bonestock98GS's Avatar
Default Compression Question
Well My setup was told to me as I bought the car as having 12:1 compression and stock GSR rods. GSR block and B16 head. Head is Stock. We did a compression test and we got 240 all across the board. My friend was telling me to ask you guys if 240 across the board meant that it has those 12:1 pistons or is this motors block completely stock? I need help with this question ASAP because I am going to boost by the end of the week thanks
Old Aug 31, 2009 | 08:18 PM
Default Re: Compression Question
bump
Old Aug 31, 2009 | 08:42 PM
vadimkag's Avatar
Stock rods...? Trust me stock rods are risky and yah 240 should be high compresion pistons. I would say pool the head out, put stronger rods and low comprecion pistons and I would recomand to put new rod bearings, new obd2 oil pump, oem or stronger timing belt and ARP or Eagle head studs. Thats the at leas the right way to go other wise waste of money and time, alot of time. Good luck.
And 7lbs of boost is waste of money.
Old Sep 1, 2009 | 08:57 AM
bump ttt
Old Sep 1, 2009 | 01:25 PM
Old Sep 1, 2009 | 01:49 PM
E85B18's Avatar
240 is pretty high, could very well be 12:1. 12:1 is really high for a boosted application. You'll have to run low boost like 5psi
Old Sep 1, 2009 | 06:53 PM
?????????? more answers guys
Old Sep 1, 2009 | 07:09 PM
slow96lude's Avatar
the stock gsr can hold that much pressure with a new set of rings on stock pistons. helms states that 270 should be perfect
Old Sep 1, 2009 | 07:20 PM
so is it possible that my block is still filled with stock pistons?
Old Sep 1, 2009 | 07:51 PM
slow96lude's Avatar
yes sir
Old Sep 1, 2009 | 08:14 PM
cool thanks man that soes it I am turboing the **** out it now lol
Bonestock98GS
Sep 7, 2009 12:43 PM
ljs88
Jul 15, 2007 01:14 PM
GSRerrr
Apr 4, 2005 07:11 PM
99lsvtecauto
Feb 27, 2004 07:58 PM
trillo
May 24, 2002 01:19 PM
