best blockguard to get?
Old Nov 30, 2008 | 01:56 PM
BLT4SIN's Avatar
Default best blockguard to get?
im turboing my stock GSR soon on 10 pounds, and alot of people told me i need to use a blockguard, and ive seen a bunch of different brands, golden eagle, supertech, blox, etc.
i was wondering which ones were good to get and which to stay away from.
Old Nov 30, 2008 | 02:53 PM
boostedcivicsir's Avatar
Mr. Badwrench
no guard needed at 10 psi.
Old Nov 30, 2008 | 05:13 PM
Schister66's Avatar
Man U FTW
Stock sleeves or aftermarket sleeves...there are no other options. Blockguards are just for peace of mind. Save yourself the $100 and hassle by not getting one...
Old Nov 30, 2008 | 05:26 PM
mtber's Avatar
For 10 psi (assuming your running an average sized turbo). You will not need a block gaurd or sleeves as you will probably not yield anymore then 350 whp.
Old Nov 30, 2008 | 11:13 PM
quicksilver1689's Avatar
i ♥ snails
block guards are junk enough said
Old Dec 1, 2008 | 07:52 AM
HiProfile's Avatar
My brother's first turbo car was a 95 GSR - that used an FMU. It made 305whp at 11psi with a 54trim, rather unsafely though. There definately wasn't an issue with the sleeves, despite the high amount of timing it had because of the FMU setup.
Go back to those people and laugh at them, unless you plan on an untuned setup. Nothing will save that kind of crap.
Old Dec 1, 2008 | 10:36 AM
tony tone's Avatar
GDD Moderator
i have one just because it was in there when i bought it. if not, there wouldn't be one. your sleeve will crack with or without it. 10psi is fine without one.
Old Dec 1, 2008 | 10:39 AM
SOHC_MShue's Avatar
dont use one
Old Dec 2, 2008 | 12:45 AM
Fresh'86's Avatar
Waste of money
Old Dec 2, 2008 | 01:15 AM
harhoosh's Avatar
Default block guard
Originally Posted by Fresh'86
Waste of money
I am using one on my b20 stock sleeves on more than 30psi with PT6765.
i think it save my block.
Old Dec 2, 2008 | 02:38 AM
SD_Lurker's Avatar
HT White Ops
You thought wrong.
Old Dec 2, 2008 | 11:25 AM
BLT4SIN's Avatar
thanks for the feedback, and the turbo i was going to run was a t3/60-1. and i was going to get it tuned on AEM. so ill think ill go without a blockguard for now.
Old Dec 2, 2008 | 11:16 PM
kicked25th's Avatar
I personally like the GE block guards. Block posting most say is better though. Stock sleeves always need help
DCtooD
Jul 28, 2010 07:43 PM
da1haloking
Mar 15, 2009 01:52 PM
alpha_1
Sep 16, 2004 04:29 PM
Btothe3rdDegree
Aug 16, 2003 09:08 AM
compwc18
Jul 31, 2003 06:26 PM
