Tuning ls/turbo crx
Old Nov 30, 2008 | 01:32 PM
91lsturbocrx's Avatar
Default Tuning ls/turbo crx
I plan on getting my crx dyno tuned. To do that do I need to get a jumper harness and change ecus or can it just be tuned the way it is?
Old Nov 30, 2008 | 01:40 PM
mar778c's Avatar
Community Builder
Community Influencer
If your car is OBD-0 then you can tune a chipped PR3 or PW0 with BRE but you will be limited in terms of tuning capablilities.
Plus not a lot of tuners are familiar with BRE.
Old Nov 30, 2008 | 05:28 PM
mtber's Avatar
A lot of dyno tuners don't tune obd0 systems anymore. Contact your local dyno tuners for information on this.
If you require to upgrade from obd0 to obd1 you will need an obd1 distributor, obd0 to obd1 harness & distributor jumper along with an obd1 chipped ecu running which ever engine management system your tuner supports.
Old Dec 1, 2008 | 10:12 AM
So my ls is obd0?
Old Dec 1, 2008 | 10:22 AM
If my ls is obd0 i could get these then get it tuned right?
_W0QQcmdZViewItemQQ_trkparmsZ66Q3a2Q7c65Q3a3Q7c39Q 3a1Q7c240Q3a1318QQ_trksidZp3286Q2ec0Q2em14QQhashZi tem380086002544QQitemZ380086002544QQptZMotorsQ5fCa rQ5fTruckQ5fPartsQ5fAccessories
http://cgi.ebay.com/ebaymotors/Civic...3A1|240%3A1318
Old Dec 1, 2008 | 10:34 AM
LA_HONDAS's Avatar
yes thats the ecu jumper harness
the ecu you can use but you will need a obd1 or obd2 dizzy and a obd0 to obd1 or obd0 to obd2 dizzy conversion harness
Old Dec 1, 2008 | 11:52 AM
So I can use that ecu that i posted? Could you please post a link to the exact harness I need?
Old Dec 3, 2008 | 07:48 AM
LA_HONDAS's Avatar
http://phearable.net/shoppingcart/ob...mper-p-75.html
yes you can use that ecu
Old Dec 3, 2008 | 02:19 PM
ok thanks la hondas
Old Dec 3, 2008 | 03:02 PM
that link you posted said distributor jumper, don't I need the ecu jumper?
Old Dec 3, 2008 | 04:35 PM
LA_HONDAS's Avatar
yes you need both
you have a link for the ecu jumper harness up top
Old Dec 4, 2008 | 04:12 AM
So Do I need a obd1 distributor too for everything to work right?
Old Dec 4, 2008 | 08:10 AM
burningrex's Avatar
yes and an obd1 distributor...
Old Dec 4, 2008 | 04:27 PM
ok thanks guys
Old Dec 6, 2008 | 08:11 AM
can I use this distributor?
http://cgi.ebay.com/ebaymotors/DISTR...Q5fAccessories
Old Dec 7, 2008 | 06:43 PM
LA_HONDAS's Avatar
yes you can use it
Old Jan 10, 2009 | 08:23 AM
Default Re: Tuning ls/turbo crx
Do I need to get a 4 wire o2 sensor for the obd0 to obd1 conversion?
Old Jan 10, 2009 | 09:02 AM
mtber's Avatar
No, you don't if the o2 sensor is disabled in the ecu.
Old Jan 10, 2009 | 03:04 PM
Blown90hatcH's Avatar
You do not need a distributor jumper, but it makes it convenient. You can use either an OBD1 or OBD2 distributor. If your ecu tuner has disabled the O2 sensor, then you do not need the four wire O2 sensor as Mtber has stated. I highly recommend getting a quality ecu harness, distributor and ecu as wiring is something overlooked and cheaped out on so many times. First time you need a tow or have to pay someone to fix the mistakes, you will thank me.
http://rywire.com/store/obd0-obd1-co...23a1f910b2aab3
http://rywire.com/store/-c-32.html?o...610cccb73e6630
ryanangelo212
Mar 18, 2013 12:23 AM
blaak-crx
11
Sep 10, 2009 11:51 AM
CraiGlOl
Feb 7, 2009 03:03 PM
My_EFsedan
Oct 25, 2008 11:21 AM
-KangaRod-
Jul 8, 2004 11:02 AM
