New EM1 OEM Lip fitment
Old Nov 30, 2008 | 09:04 AM
YoungMoneySi's Avatar
Default New EM1 OEM Lip fitment
hey guys i just recently got me a new OEM lip for my em1 but there are gaps in the corners from the lip to the bumper. why is that? is there a certain order i need to go with? start inside and work inside? i started outside and worked inside. the lip and the bumper are both OEM honda.
thanks guys!
Old Nov 30, 2008 | 09:52 AM
krazyhmongboi's Avatar
bottom up. helps to have someone helping you also
Old Nov 30, 2008 | 10:50 AM
redline7070's Avatar
got any pic to see how it is fiting
Old Nov 30, 2008 | 11:02 AM
completely forgot my photobucket ID and PW but basically it fits good from the middle on except a minor gap in between where you screw from the sides and the first bolt
Old Nov 30, 2008 | 12:06 PM
BuiltforSin's Avatar
Post
Taken from the Honda IN.
1.Using a pushpin, pierce the front bumper at the
centers of the four dimples on the right and left ends
of the front bumper as shown. Slide a spring nut over
each hole you just made.
2. Slide a clip nut onto the front bumper through each
of the nine cutouts in the front bumper. Slide the
spring nuts onto the front bumper.
3. Position the under spoiler on the front bumper, and
install the nine shoulder bolts and four self-tapping
screws.
To The Dealer Service Technician:
Please copy this page and give the copy to your customer.
• Be sure to remove the front under spoiler from the front bumper when a hook is used to tow the car.
1. Remove the nine shoulder bolts and four self-tapping screws to remove the front under spoiler from the front
bumper.
2. Reinstall the front under spoiler in the reverse order of removal after using a hook.
If you installed it like this then there should be no problems.
Old Nov 30, 2008 | 12:14 PM
hey thanks i actually have that and another official honda manual but i guess is should install the shoulder bolts first and then the four screws on the ends. i did it the other way around and installed the 4 screws and then the shoulder bolts.
k i will try this and see what happens.
i will let yall if it works or not.
thanks guys!
DEATHB4DlSHONOR
Mar 6, 2010 05:19 AM
brutekiller787
Jan 23, 2009 03:28 PM
2oo6 s2k
Honda S2000
13
Aug 22, 2006 02:26 PM
Tuesdaynightfever
Mar 28, 2005 06:09 PM
CoxhEd
Aug 25, 2004 06:46 PM
