location of the 2nd o2 sensor outlet?
Old Nov 29, 2008 | 11:27 PM
FRKWOO's Avatar
Default location of the 2nd o2 sensor outlet?
i had a recent y7 to y8 motor swap in my ek with 00 ex wire harness. i had a local shop known for honda motor swaps to hook the wire harness up for me and when they were done they said the secondary o2 outlet was missing and all i needed to do was get a p28 ecu and jumper harness and convert to obd1. i wanna keep obd2 and just want to add the second o2 back on. i need help on which part of the wire harness the secondary o2 snesor goes i have another cut outlet and o2 sensor ready to go.
Old Nov 29, 2008 | 11:46 PM
20civic0000si's Avatar
The second O2 comes off the Car harness in the EX/SI and off of the engine harness in the rest of the civics. Just depends on which engine harness and header you are using.
If your using the Stock harness w/the stock header which is what it sounds like you are using, then you have to add a second O2 bung and a Jpipe and run the wires to the factory Secondary plug.
If your using the Y8 engine harness your still going to need a Jpipe but just run the wires to the ECU.
Old Nov 30, 2008 | 04:17 PM
FRKWOO's Avatar
im running megan 4-2-1 headers with stock 00 civic ex harness in my 00 ek
Old Nov 30, 2008 | 06:26 PM
redline7070's Avatar
the second O2 **** out of the floor to the cat
Old Nov 30, 2008 | 07:07 PM
FRKWOO's Avatar
im talkin about where do i connect the connector outlet for the o2 sensor to the engine wire harness
Old Nov 30, 2008 | 07:13 PM
you have to run new wires to it or put a ex/si floor harness in. on the ex/si the 2nd o2 is on the floor harness at the shift
Old Nov 30, 2008 | 07:18 PM
FRKWOO's Avatar
can you put in more detailed form if possible?
Old Nov 30, 2008 | 07:34 PM
hondahookup.com hasthe service manual you can get it on page 2187 has the 2nd os
http://www.hondahookup.com/manuals/
stiffinEK
Mar 8, 2009 09:43 PM
HatchSpeeD
May 23, 2008 05:17 PM
exare250
Nov 24, 2004 10:59 AM
sleeperek
Oct 24, 2004 08:50 AM
mjrage
23
Aug 16, 2004 10:12 AM
