SOHC SWAP INFO!!
Old Nov 28, 2008 | 11:33 PM
pemd5555's Avatar
Default SOHC SWAP INFO!!
So I'm looking to do something crazy and different. It involves swapping an 2001-2005 sohc engine into an eg hatchback. Sooo my question is what mounts do i use? Would I use k-series hasport mounts or what? any info would be great
Old Nov 29, 2008 | 12:22 AM
dividedas1's Avatar
Old Nov 29, 2008 | 12:27 AM
D16SiHatch's Avatar
definately not worth the effort. theres a reason you've never heard of or seen anyone attempt this swap. its far cheaper to stay with d-series in the 92-00 range. using the newer engine would require a crap ton of extra parts and fab to make it work, and it wouldn't be worth it for the power they make.
Old Nov 29, 2008 | 06:10 AM
wrenchez81's Avatar
not ta mention the d17's obdII
Old Nov 29, 2008 | 11:07 AM
andoxviii's Avatar
To do this swap, all the same type of work needed for a K20 swap is needed. So if you are going to do all the work for a K20, why put a D17 instead?
Old Nov 29, 2008 | 09:52 PM
pemd5555's Avatar
I wanna swap a hybrid motor into an eg thats the reason why I needed to know what mounts to use. I can do wiring thats not an issue.
Old Nov 30, 2008 | 02:07 PM
98civdx's Avatar
Master Detailer
hasport and avid, may be able to help
but i never heard of anyone doing that.
you might as well buy a hybrid.
Old Nov 30, 2008 | 06:34 PM
pemd5555's Avatar
I could... but an eg hatchback 5 lug with hybrid wheels and hybrid swap? c'mon that would be kind of cool
pemd5555's Avatar
not to mention a lot cheaper than a new hybrid
Old Nov 30, 2008 | 07:52 PM
forcefedferio's Avatar
meh, that's not even close to worth the effort, cool yes and i would deffinetely respect it if it were done.
why not do the k-swap and have it tuned on e85? just my .02 i think it'd be alot more enjoyable but still unique on e85
Old Dec 10, 2008 | 08:36 AM
pemd5555's Avatar
Well my whole deal is that I want to have the looks of an eg hatchback, but amazing fuel economy. I'm a honda pact student and i'm thinking the only real challenge is going to be the wiring. I'd have to take the chassis harness of the hybrid along with the engine harness and swap that all into an eg shell. The fuel set up is probably different, so I'd have to work all these things out. But a five speed hybrid in a hatchback would be decently fun to drive. The motor, battery, tranny, and wiring run about 3k for the whole swap
Old Dec 10, 2008 | 09:16 AM
94EG8's Avatar
Seagull Management
Its called a VX hatchback. Seriously its not worth swapping a hybrid drivetrain into a 5th gen chassis.
Old Dec 10, 2008 | 09:37 AM
alphalanos's Avatar
much cheaper and easier to stay with what works. if you did this d17 swap you would eventually get to a point and think " why the F am i doing this"
Jap.Doe
Aug 14, 2012 06:44 AM
civic eg k20
Nov 20, 2007 01:54 PM
blessedrican
Nov 18, 2007 12:10 PM
CaptainMorgan
Mar 31, 2007 12:26 AM
dgrave
Dec 14, 2004 07:05 AM
