SOHC SWAP INFO!!
Old 11-28-2008, 11:33 PM
pemd5555's Avatar
Default SOHC SWAP INFO!!
So I'm looking to do something crazy and different. It involves swapping an 2001-2005 sohc engine into an eg hatchback. Sooo my question is what mounts do i use? Would I use k-series hasport mounts or what? any info would be great
Old 11-29-2008, 12:22 AM
dividedas1's Avatar
Old 11-29-2008, 12:27 AM
D16SiHatch's Avatar
definately not worth the effort. theres a reason you've never heard of or seen anyone attempt this swap. its far cheaper to stay with d-series in the 92-00 range. using the newer engine would require a crap ton of extra parts and fab to make it work, and it wouldn't be worth it for the power they make.
Old 11-29-2008, 06:10 AM
wrenchez81's Avatar
not ta mention the d17's obdII
Old 11-29-2008, 11:07 AM
andoxviii's Avatar
To do this swap, all the same type of work needed for a K20 swap is needed. So if you are going to do all the work for a K20, why put a D17 instead?
Old 11-29-2008, 09:52 PM
pemd5555's Avatar
I wanna swap a hybrid motor into an eg thats the reason why I needed to know what mounts to use. I can do wiring thats not an issue.
Old 11-30-2008, 02:07 PM
Master Detailer
98civdx's Avatar
hasport and avid, may be able to help
but i never heard of anyone doing that.
you might as well buy a hybrid.
Old 11-30-2008, 06:34 PM
pemd5555's Avatar
I could... but an eg hatchback 5 lug with hybrid wheels and hybrid swap? c'mon that would be kind of cool
pemd5555's Avatar
not to mention a lot cheaper than a new hybrid
Old 11-30-2008, 07:52 PM
forcefedferio's Avatar
meh, that's not even close to worth the effort, cool yes and i would deffinetely respect it if it were done.
why not do the k-swap and have it tuned on e85? just my .02 i think it'd be alot more enjoyable but still unique on e85
Old 12-10-2008, 08:36 AM
pemd5555's Avatar
Well my whole deal is that I want to have the looks of an eg hatchback, but amazing fuel economy. I'm a honda pact student and i'm thinking the only real challenge is going to be the wiring. I'd have to take the chassis harness of the hybrid along with the engine harness and swap that all into an eg shell. The fuel set up is probably different, so I'd have to work all these things out. But a five speed hybrid in a hatchback would be decently fun to drive. The motor, battery, tranny, and wiring run about 3k for the whole swap
Old 12-10-2008, 09:16 AM
Seagull Management
94EG8's Avatar
Its called a VX hatchback. Seriously its not worth swapping a hybrid drivetrain into a 5th gen chassis.
Old 12-10-2008, 09:37 AM
alphalanos's Avatar
much cheaper and easier to stay with what works. if you did this d17 swap you would eventually get to a point and think " why the F am i doing this"
Jap.Doe
08-14-2012 06:44 AM
civic eg k20
11-20-2007 01:54 PM
blessedrican
11-18-2007 12:10 PM
CaptainMorgan
03-31-2007 12:26 AM
dgrave
12-14-2004 07:05 AM
Quick Reply: SOHC SWAP INFO!!
