Any Body Shops In So Cal For HELP ON ITR Front End Conversion
Old Nov 27, 2008 | 01:37 PM
HondaTypeR001's Avatar
Default Any Body Shops In So Cal For HELP ON ITR Front End Conversion
Hey Guys I just got a JDM ITR Front end for my DC2 GSR, and i was told that i needed to make hole some where in the front end so it can fit good on my Integra for like $60 bucks...If you guys know any in So Cal let me know with their number or address. Oh before i forget, i need to get a fender bracket. If you guys know any place or websites, I would really appreciate it. Thanks!
Old Nov 28, 2008 | 05:14 PM
EnjoyTheRideDC2's Avatar
I have no idea what you're talking about. Some "Hole" to make it fit better?
Are you having fitment issues? Maybe they just want you to spend 60 bucks to put a hole in your wallet? But seriously, why did they mention it in the first place?
Old Nov 29, 2008 | 03:12 PM
Thanks for the reply...Well the guy at passwordjdm told me that i need to get hole at the bumper support...but other than that just bolt it on...how the ITR conversion work? and what do i do?
Old Nov 29, 2008 | 03:16 PM
fdrf's Avatar
i highly suggest you get rid of the front end.
Old Nov 29, 2008 | 03:44 PM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
The front end conversion is alittle more complicated than whomever at Password told you.
You will need to drill out all the welds on your stock radiator support then weld in the JDM Integra radiator support. Some people do the T bar coversion which still includes alot of cutting and, ideally, welding in the jdm t support.
Then you'll have to splice in the harness for the JDM headlights.
For the record, there's no "hole" to be made. I dont know what you're refering to. Best thing to do is do a search on JDM Integra front end conversions and see what is really involved. You will probably have to take your car to a body shop to have them do the work - it wont be cheap.
Old Nov 30, 2008 | 10:55 AM
So how much would it be to do all that work?
Old Nov 30, 2008 | 05:11 PM
emooheo's Avatar
haven't really looked into it but from what i have seen, a shop in norcal does it for $400
Old Dec 1, 2008 | 05:41 PM
Well if thats how much for the front end to get installed...so does anyone know one in So Cal?
Old Dec 8, 2008 | 12:29 PM
JDMWEST's Avatar
Nobody will help you for $60. theres alot of work involved. minimum is about $200 and thats with no welding.
Old Dec 8, 2008 | 12:32 PM
4banger1986's Avatar
what the ****?
Old Dec 8, 2008 | 12:54 PM
jdmdc2boi12's Avatar
if i wer u i would just do it myself like i did,i was being charge 1600 installation plus paint.. its pretty easy, all u need is drill all the spot weld on that orig radiator.. after that everything is bolt on unless u know how to weld.. its worth it!!!!
check mine
http://s249.photobucket.com/albums/g...t=e07015f8.pbr
Old Dec 8, 2008 | 05:07 PM
Well I dunno how to weld...is it hard?
Old Dec 8, 2008 | 05:45 PM
no! but u will need to practice on something first.. or do what my cousin did, he cant afford to buy a welder or get it weld.. so instead of getting it welded he just drilled through the spot welds and he screwd those things using homedepot screws..it held up pretty good and its been over 2 yrs now and still pretty good.. this is just an exmple jst to give u some ideas..U know wat spot weld looks like right?
Old Dec 8, 2008 | 05:50 PM
tempname's Avatar
That just might be the worst thing I've ever heard. OP please don't hack up your car and turn it into a potential nightmare for the next unsuspecting owner. Get it done right, weld it please. If not, just sell it to someone who is prepared to install it properly.
Old Dec 12, 2008 | 11:07 AM
Does anybody know what spots to weld? Or any pics showing what to weld...
Old Dec 12, 2008 | 12:51 PM
the red dots the spot welds, same for the other side.. will delete pic/owner request..
this is a drill bit u need for those spot welds. this will do the job perfectly. this is the same i used. u can get them at napa auto store or any auto store
price is $14.99 or less
good luck, id say do it ur self..u will save lots of money.. if u need help on wiring the lights let me know.. i can make u a write up
MyDeeCee2
Jan 7, 2011 04:17 PM
Outraged182
Jul 19, 2008 06:28 PM
DarkDC2
Mar 25, 2006 09:14 AM
Therumblingteg
Mar 2, 2003 07:52 PM
capcon83
Feb 23, 2003 02:03 PM
