ITR front end conversion
Old Jan 6, 2011 | 03:04 PM
MyDeeCee2's Avatar
Icon6 ITR front end conversion
hey you guys, i just recently bought my ITR front end conversion for my 1997 Ls Integra. i have everything except the radiator support(hood bumper fenders) i need the grill too but ya.. i should be getting it tomorrow. i have heard diff things about the radiator support and i was wondering if its a hard process or am i able to do it by myself? does it involve any welding or is it just bought on? i need some tips and feedback. thanks! ill post pics when its done im sure this has already been discussed on here.. so if nobody wants to help you can direct me to the right thread. thanks haha im new
Old Jan 6, 2011 | 03:08 PM
jdmer329's Avatar
Default Re: ITR FRONT END CONVERSION
i would drill holes and use bolts and jus tighten it on cause if there is any gaps or not fitting well you can jus looses the bolts and help shape how you want it. if you weld its jus gonna be how it is lol you can change any small inperfections. just my 2 cents. ive never done one or read how to do it, im just using common sense. and i have heard of alot of people jus bolting it on so thats why im thinking the reason behind it.
Old Jan 6, 2011 | 03:15 PM
MyDeeCee2's Avatar
Default Re: ITR front end conversion
hmm alright. you do have a point with the welding lol. if i do it.. its stuck like that. lol i just dont want anything to be loose ya know?
Old Jan 6, 2011 | 05:26 PM
CB's Avatar
CB
Don't just bolt the radiator support on... Sh*t is going to move. Do some research man, there is plenty of information on this.
Old Jan 7, 2011 | 11:41 AM
94 ls-r's Avatar
No welding is a horrible idea. First time a tow truck hooks up the the tow hooks it will bend the hell out of your clip. Plus if you ever do get in a wreck it wont hold up well
Old Jan 7, 2011 | 11:58 AM
aveink07's Avatar
definitely need to weld, its not the hardest thing to do but you definitely need experience in making sure everything is squared away and welding it. also you need to cut around the inside the frame to fit the headlights. Everything else is pretty easy hood, fenders all bolt up. One more thing you need to get is a 90-93 integra hood latch and cable because the stock Integra cable isn't long enough and the hood latch release is facing the wrong way. But in my opinion get a professional body shop to at least install the rad support
Old Jan 7, 2011 | 12:05 PM
mouseitr's Avatar
yeah unless you know body work its gonna be insane tryin to do it yourself, so my personal opinion is get it professionally installed
Old Jan 7, 2011 | 04:01 PM
wreckeddc4's Avatar
Welding is a must. Almost 100 spot welds must be drilled out to remove old rad support, and they must be re welded for structural strength. Best have a body shop do it if you have no welding equiptment or knowledge.
Also from my experience, most used jdm front clips are bent some, simply because they come off totalled cars. Mine required some heating with a torch and some finess with a body hammer to get it straight. But once that was done it almost fell into place, and I had to weld in all the holes from the spot welds.
Check the for sale post in my sig for my car, the hood/ fender gaps are almost perfect after my jdm front.
Old Jan 7, 2011 | 04:17 PM
AnDThEnWuT's Avatar
This is the proper way to go about it, but if you are on a budget and can't afford a shop to do the work, go the simpler route. Just use the T-Bar approach, no real modifications to the stock radiator support, just the top half. You can either bolt it up or weld it when you do have the cash, it is really simple to do. I did mine last summer and only took about a day to put everything together. There is a thread on here that I followed word for word. https://honda-tech.com/forums/honda-acura-28/jdm-dc2-integra-conversion-official-how-instructions-mod-reid-approved-1346217/
Honda_lazz
Mar 26, 2014 03:10 PM
HondaTypeR001
Dec 12, 2008 12:51 PM
hmongyaj87
Apr 17, 2007 06:59 PM
JDean6pac
12
Mar 23, 2007 01:44 PM
BlackDC4
Jan 23, 2006 02:44 AM
