Need help with broke tool down oil passage.
Old Nov 26, 2008 | 03:45 PM
slugo10's Avatar
Default Need help with broke tool down oil passage.
Crappy ending to a good day of working on my engine. So I decided to change the valve stem seals on my B18C today. Everything went great until i used a cheap center punch to hold the cams while i torqued the cam gears on. The punch broke and the cam turned and the broke part fell into the oil passage between #1 an #2 cylinder valves. So my question is does that go straight down to the oil pan? I hope it does so I can pull the oil pan and find it.
Old Nov 26, 2008 | 04:22 PM
b16_sol_707's Avatar
easiest way to tell it to take the oil pan off and look.
Old Nov 26, 2008 | 04:39 PM
abusedhusband's Avatar
get a small telescoping magnet and stick it in the hole and hope you pick it up. if not take the oil pand and windage tray off and search.
Old Nov 26, 2008 | 05:03 PM
gutted-dx's Avatar
I just had the samething hapen to me with 2 keepers, had to drop the header, oil pan, pickup, then windage tray. It was pretty gay but i found it! Good luck.
Old Nov 27, 2008 | 03:51 AM
slugo10's Avatar
Default ..
So the oil passage does go striaght down to th eoil pan? It was about a 1 inch piece that broke off and fell down.
Old Nov 27, 2008 | 06:06 AM
slugo10's Avatar
Default ..
Well i pulled the oil pan off and then the windage tray and there that little piece of S*%T! broken part lay. Glad i found it, now I will feel better not having to worry where it went. Thanks for the help again!
Old Nov 27, 2008 | 06:48 AM
gutted-dx's Avatar
Suprising how it actually goes to the oil pan and not get stuck in the passage.
Old Nov 27, 2008 | 01:48 PM
slugo10's Avatar
Ya i guess it's a pretty big gap down from head to oil pain.
Old Nov 30, 2008 | 06:44 PM
gutted-dx's Avatar
Gotta get all the oil off them cams back to the pickup.
hondaboy4life
Sep 29, 2006 08:01 AM
thegeorge613
Jul 31, 2006 05:02 PM
RHDintegXsi
Jun 17, 2006 04:20 AM
bluecb7
Mar 14, 2004 04:51 PM
