gasket issue with p&p'ed head
Old Nov 25, 2008 | 09:45 PM
ntoxicatedtigah's Avatar
Default gasket issue with p&p'ed head
so if you have port and polished head intake and exhaust side, would there be stock gasket issues?
Old Nov 26, 2008 | 12:14 AM
tepid1's Avatar
Which gasket? Head, intake or exhaust? You may have to open up the ports on the gasket a bit....
Old Nov 26, 2008 | 04:53 AM
Mikey3000's Avatar
it should only be opened up to gasket size, hence no gasket issues.
Old Nov 26, 2008 | 07:36 AM
rip94delsol's Avatar
Then why even bother porting a head? that doesn't seem right to me.
on my hondata gasket I had to port it out just a little bit but nothing extreme!
You wont any issues.
Old Nov 26, 2008 | 08:13 AM
Blake8418's Avatar
port match the gaskets.
If you port a head and havn't even gone bigger than the gasket...........you havnt done much.
Old Nov 26, 2008 | 08:30 AM
pigeonkiller22's Avatar
my guees is to just port the gasket because when i ported my head i kept the oem gaskets on both sides but when i went to go dyno it was loosing 5hp and 3 of tourque i found that out because the guy that dynoed it ported the gaskets and the power increased. but i ported the holes preatty big.
hope this helps
Old Nov 26, 2008 | 08:54 AM
Mikey3000's Avatar
the theory is, that unless you have manifolds whos ports are the same size as stock, you're not gaining anything by englarging the ports on the head. then what you'll get is a column of air knocking into that overhang that you've just created. i think the features on a head that net the most change are the throats of the ports (not the mouths) and the chamber itself.
Old Nov 26, 2008 | 10:44 AM
Blake8418's Avatar
if your intake/exhaust is the same size as your gasket , then their would be no point in making the gasket match the head but if your manifolds are matched up to your head[which they should be for the most power] then you would need to port the gasket too.
Old Nov 26, 2008 | 10:47 AM
Blake8418's Avatar
and yea the most power comes from the flow/shape of the port rather than the size but a good port job is gonna be bigger in the mouth too.
B18C_EJ8
Apr 25, 2007 09:05 AM
Chuethou_b18c5
May 1, 2006 11:51 PM
drewlee
Aug 9, 2004 12:00 PM
