civic dies out of no where.
i have a 93 honda civic and it dies once in a while.. it doesnt die all the time but just sometime when i stop. it sounded like it bogs right when i try to move and it dies. so i replace the fuel filter and that wasnt the problem so then i got new spark plug and wires and it still does it.. it doesnt die all the time just once in a while so i want to fix it before it gets worse. what else could be the problem.
ok i will change the rotor and the cap and how do i check the coil and the ignition control module. and i will clean the idle controle valve tomorrow and let you know how it is.
how do you spray something into your IACV? without disconnecting the coolant hoses or even taking it off for that matter, while your engine is running? can you elaborate a bit more for the OP...i cant see this possible. either way like mentioned before try checking dizzy(cap, rotor, ICM, coil) mine died it was the coil but sense your dies only randomly...try to see if your grounds are tight.
yea i know how to clean adle air control valve if you dont know how to then here is a link. https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
but i dont know how to check the coil or ICM going bad, if some one can show me how to chekc it is much appreciated. thanks.
Use only OEM parts. They are not that much more expensive and pay for themselves in longevity and saving wear and tear on other parts. Your best prices for OEM parts generally are at online parts sites like www.bkhondaparts.com
An excellent resource for narrowing down and correcting start/run problems is http://www.tegger.com/hondafaq/faq.html#startrun . This site is based on the many anecdotal reports on honda forums of start/run problems, so it too is about probability.
so i opened up my distrupitor and notice the rotor and the cap looks really bad, so i replaced it. then the little spring on the ignition control moduel came off and was wondering if i need that because it feels like imposible to put it back on it.
sethmoman
12
Dec 28, 2011 10:00 PM
mid_life_crisis
Jun 15, 2011 03:58 AM
averyvm
Apr 14, 2009 02:10 PM
dividedas1
Mar 16, 2009 08:13 AM
