help! turbo 99 si problem!
Old Nov 22, 2008 | 04:07 PM
longshot's Avatar
Default help! turbo 99 si problem!
the #1 cylinder is dead, so we put new injectors in it. and then it was still dead, so i took the spark plug out to make sure it was firing, and it is, but i didnt smell gas in the cylinder...
now heres the problem, the car is obd-2 to obd-1 and they had to wire in resistors? but i dont know how to check if its wiring or what.. so confused..
ty in advance
Old Nov 22, 2008 | 04:09 PM
.dave's Avatar
i HAS questions ?
I would trace the wire back along the harness and check the connections. If they did a poor solder job the connection could be broken.
Old Nov 22, 2008 | 04:12 PM
longshot's Avatar
but the thing is, it gets power to the resistor side, before and affter the resistor, and i dont know, plus weve tried that.
Old Nov 22, 2008 | 04:14 PM
z6hatchboy's Avatar
try checking the rest of the injectors harness
Old Nov 22, 2008 | 04:15 PM
.dave's Avatar
i HAS questions ?
Check the ground side if they put different injector clips on.
Old Nov 22, 2008 | 06:10 PM
longshot's Avatar
well... we just tried switch the wires around, tried puttin a new resistor in, but if you put a plug from a different cylinder on the dead cylinder it works fine...
LuckyStrike90
Aug 2, 2024 12:10 AM
918accord
Jul 27, 2010 12:53 PM
Ron454321
Jul 25, 2007 07:56 AM
ek4__
Apr 12, 2007 04:42 PM
Brooklyn101
Oct 30, 2006 11:51 AM
