b18b n/a in a 92 cx stupid or smart???
would like to hit mid 13's... Is this a waste of my time and money??? If not what all needs to be done?? I dont know anything about these engines...even what brand of i/h/e to buy.... this car also needs to be a daily driver.... thanks for the help...
id go for a b18c motor personally.
torque owns.
stick around HT and use the search button ALOT. you can find 99% of your questions in there.
edit: didnt this say b16a origionally?
[Modified by KAMiN, 2:05 AM 8/1/2002]
torque owns.
13's are obtainable...if you do a look under the Drag Racing forum, people are hitting 14.5s and 14.4s on stock LS with b16a or GSR transmissions. Don't keep the LS tranny if you plan on going N/A...
Yah I did a search and didnt find anything. Stock ls motor meaning nuthing but the motor or motor plus bolt ons. Ill do another search and see if I find anything. Thanks for the help....
If you plan on doing this swap I assume you want more performance than stock?right? Few years back when I bought my B18B motor I thought the same thing........affordable, more performance, etc, etc. After ALLOT of $$, the best I could squeeze out of my B18B was 177 and old one 189 all motor non vtec. Save some more and either get a GSR or H22 swap? Although these will cost more than an LS swap, their potentials are more easily reached with less $$$. Don't get me wrong getting the B18B into low 13's is very possible It wouldn't be very street legal
[Modified by Halo, 11:13 PM 8/1/2002]
save your money...i use to have a b18b in a 93dx hatch.. i was ok, i have like intake, header, exhaust i went 14.9.. i had the crappy ls transmission too, so if you were to do this swap get a b16a trans.
As far as I know, their times were not with I/H/E....not sure though! I'm looking for high 13s with a B20Z non-vtec and either a GSR or B16 tranny in my EK...
Good luck!
Good luck!
get a B20Z if you can, the B18B won't give you as much low end torque.
I/H/E, get a gsr or b16a tranny, built the head and if you can, get some high compression pistons. You'll have NO probleme hitting 13's with that set-up...even if you don't raise the comp. Good luck.
later
[Modified by xxplosif1, 3:47 PM 8/5/2002]
later
I was just at the track this past friday and let me tell you this one guy had an all motor LS w/ b16 vtec head on it and the car wasn't really gutted out. It was 100F at the track....freakin hotter then sheep ballz
. He ran a 12.2, and he told me that was bad...from what i saw...he had a LS/VTEC w/ ITR Manifold, ITR Throttle body, ITR AEM CAI, Apex header, 2.5 inch exhaust to A'PEXi N1 Muffler, and Cam Gears. Oh and he was running on some cheap Khumo (however u spell them) 712's w/ 15 inch rotas. Hope this helps you.
Laterz
. He ran a 12.2, and he told me that was bad...from what i saw...he had a LS/VTEC w/ ITR Manifold, ITR Throttle body, ITR AEM CAI, Apex header, 2.5 inch exhaust to A'PEXi N1 Muffler, and Cam Gears. Oh and he was running on some cheap Khumo (however u spell them) 712's w/ 15 inch rotas. Hope this helps you.Laterz
Hatch It
14
Jul 28, 2005 06:31 AM
