Anybody need an oil feed line?
This is four feet of -4 stainless braided Aeroquip hose. It has a straight 4AN Aeroquip hose end on one end and a 90 degree on the other. Hose ends are STEEL. I like them better than the aluminum because they don't tear up as easy when using normal wrenches.
Used for about 2 months as a turbo feed. I replaced it with a -3 and it's been sitting around so I finally decided I can't find anything else to use it on so I'm selling it.
Retail cost was about $42 in parts plus shipping. I'll sell for $30 shipped.
[Modified by mplex2000, 7:22 AM 8/1/2002]
The only other things you'll need are:
(2) 1/8" NPT to 4AN adapters, they're like 1-2 bucks each.
Depending on how you want to set it up, you might also want a T fitting and/or a 1/8" BSPT to 1/8" NPT adapter. If you want a complete setup I should be able to provide that also at additional cost.
