Which fuel pump to run?
I have a b20vtec, and was told that the stock CX fuel pump won't be good enough. Should I upgrade to a aftermarket one, or would something off a gsr be good enough? If aftermarket, then what would you recommend?
gsr, type r, holly, jackson.
anything better. they all basically do the same thing. i would probably go with something aftermarket, but an OEM one from a gsr or type r should be ok.
I don't plan on getting anymore then 250 to the wheel. So I guess a OEM one would be good. Since I don't want to buy one with a lot of mile on it how much does a new one from the dealer cost? Either gsr, si, or type r.
[Modified by Vanilla4215, 8:05 PM 8/1/2002]
fuel pumps from the dealer are 200+ so you might as well get an aftermarket one
