Which fuel pump to run?
Old 07-31-2002, 09:13 PM
Vanilla4215's Avatar
Default Which fuel pump to run?
I have a b20vtec, and was told that the stock CX fuel pump won't be good enough. Should I upgrade to a aftermarket one, or would something off a gsr be good enough? If aftermarket, then what would you recommend?
Old 07-31-2002, 10:05 PM
2camsaam's Avatar
Default Re: Which fuel pump to run? (Vanilla4215)
BBK pump only lik $130
strong pump
Old 08-01-2002, 01:37 AM
Default Re: Which fuel pump to run? (Spool)
Anyone else?
Old 08-01-2002, 02:13 AM
tonyxcom's Avatar
gsr, type r, holly, jackson.
anything better. they all basically do the same thing. i would probably go with something aftermarket, but an OEM one from a gsr or type r should be ok.
Old 08-01-2002, 02:56 AM
D Tranny Guru
Mista Bone's Avatar
if you don't plan on boost, a GSR/ITR/99-00CivSi pump will be enough.
Old 08-01-2002, 03:05 AM
Cwest EK's Avatar
Default Re: Which fuel pump to run? (Mista Bone)
I may be selling my 00 Si fuel pump soon
Old 08-01-2002, 11:05 AM
Default Re: Which fuel pump to run? (Cwest EK)
I don't plan on getting anymore then 250 to the wheel. So I guess a OEM one would be good. Since I don't want to buy one with a lot of mile on it how much does a new one from the dealer cost? Either gsr, si, or type r.
[Modified by Vanilla4215, 8:05 PM 8/1/2002]
Old 08-01-2002, 11:19 AM
tonyxcom's Avatar
fuel pumps from the dealer are 200+ so you might as well get an aftermarket one
Old 08-01-2002, 11:25 AM
Future Texas Boy
vtecvoodoo's Avatar
go aftermarket.
Old 08-01-2002, 11:26 AM
Spade's Avatar
Default Re: Which fuel pump to run? (vtecvoodoo)
After market.......walbro 255
Old 08-01-2002, 11:59 AM
Blue-Civic-Hybrid's Avatar
Default Re: Which fuel pump to run? (Spade)
I have Stock GSR pump..works good...
Old 08-01-2002, 12:01 PM
New User
Kalokohan's Avatar
Got my ITR fuel pump from a junkyard for $40 and it works perfect.
Psycho719
10-25-2011 10:00 PM
B18cFreak
08-12-2007 07:56 PM
motormike40
08-19-2006 07:32 PM
Charlie Moua
01-05-2006 05:28 PM
Quick Reply: Which fuel pump to run?
