USDM 5th gen fogs
SEARCHED. Well while messing with one of my fog wires i created a spark which turned off my other fog. thinking the bulbs were burnt i check the blubs and there fine, also checked the wiring with blubs connected directly to the battery and they work aswell. now the fogs came as a oem accesory so they either have a fuse or just a relay. thats all that can be the answer to them not working. I looked for a stock Fuse for the fogs and cant find any. can anyone help with any advice. thanks
Yes there is a fuse and 2 realys. (15amp
Read through this it should help you out.
http://www.handa-accessories.com/pre...efoglights.pdf
look at your under-dash fuse box, you should have the wiring harness for the fog lights. built into the harness is a tiny fuse. it has a wire coming into the plastic fuse holder, and then a wire coming out of it. check that one.
ckkl
Nov 6, 2002 01:42 AM
