Stainless 304 or Mild Steel for Charge Pipes?
Old Nov 20, 2008 | 08:35 PM
spoooln's Avatar
Default Stainless 304 or Mild Steel for Charge Pipes?
Which is better and Why? I have searched Google ect and found nothing more the about exhaust but I am wanting info on charge pipes. Thanks in advance
Old Nov 20, 2008 | 08:40 PM
delslo93's Avatar
I used mild steel for mine just because I had it laying around. Mild steel will rust and look crappy after a few miles of driving unless you paint it like I did.
Stainless is cool cause it doesn't rust but will be expensive.
If I were you I would save some weight and not worry about the rust and just go with aluminum piping. Spoolin' and other companies make pre-bent aluminum piping and is very nice.
Old Nov 20, 2008 | 08:42 PM
robx7fcna's Avatar
well, if it was between the 2 and you didnt mind the extra expense, I would go with stainless, for the fact that any moisture that sits in the chargepipes will not rust if the charge pipes are stainless.
However, if aluminum was an option I would go with it hands down. Lighter, no chance of rust, and able to dissapate heat quicker than the latter.
Old Nov 20, 2008 | 08:45 PM
spoooln's Avatar
I am looking into measuring out both sides so I only need 2 pieces for the whole setup and have whatever company pre bend it for me. Any companies you guys can think of that will take custom orders for aluminum? The diffrence between stainless and steel is only $1.59 a foot so not that much of an expense
Old Nov 20, 2008 | 08:54 PM
IN VTEC's Avatar
The only thing I don't like about aluminum is that it gets bent and crushed just about every time that we blow off and re-install an end of the intercooler piping. You can't crank down on the aluminum piping like you can on steel piping.
Old Nov 20, 2008 | 08:56 PM
robx7fcna's Avatar
I just used the vibrant stuff for aluminum piping. it is pretty cheap and I found it very clean and easy to weld even though it is polished.
I have used it on quite a fewe cars now (including my own)
Old Nov 20, 2008 | 08:57 PM
robx7fcna's Avatar
you need a bead roller or do the poor mans bead roller and put some weld at the end of the pipes
Old Nov 20, 2008 | 09:03 PM
spoooln's Avatar
Why would it be crushed when re-installing it and if it is thick enough I don't care how hard you crank down it won't bend or de-form.
Old Nov 21, 2008 | 12:59 AM
Tony the Tiger's Avatar
There are a lot of thinner aluminum pipes that will crush or bend when tightened down hard with a T-bolt clamp. Aluminum is also pretty easily ruined, say if the charge piping blew off during a pull and smacked the chassis or another metal object.
I would run mild steel if you are on a budget. Or if you want to be on a budget and still have a bit of bling, you can run mild steel from the turbo to FMIC, FMIC to fender, and then run SS from fender into the throttlebody.
Old Nov 21, 2008 | 08:05 AM
90blackcrx's Avatar
Aluminum
Old Nov 21, 2008 | 08:36 AM
Redline130's Avatar
I use stainless piping but only because Summit made a mistake and sent me stainless instead of mild, which I had ordered. Fortunately I only had to pay mild steel prices. I love the stainless, especially with the humidity and moisture here, zero rust thus far.
Old Nov 21, 2008 | 09:17 AM
spoooln's Avatar
I'm not on a budget. But after the feedback I think I will go with stainless steel. The benefits seem to out weight the rest " Strong, Won't rust, Easy to weld" it just seems to be a win win. Thanks for all the input guys. I will post my setup after completion. Its been in the works for a 1 1/2 now. Nothing special EG with SOHC Topmount Turbo Fully Built and kept clean.
Old Nov 21, 2008 | 10:13 AM
Turbocivic94's Avatar
aluminum
Old Nov 21, 2008 | 10:44 AM
92redhatch's Avatar
i dont see why you wouldn't go aluminum????
Old Nov 21, 2008 | 01:10 PM
AJxr's Avatar
all you min yum
xXSanderXx
Welding / Fabrication
Sep 29, 2011 07:01 AM
ntoxicatedtigah
Feb 7, 2009 11:09 AM
redboost10
Jan 19, 2004 03:54 PM
Soon_2b_evil
Oct 3, 2003 09:20 AM
nerdsports
Mar 17, 2003 05:39 AM
