backfire problem
Old Nov 19, 2008 | 03:38 PM
socal-crx's Avatar
Default backfire problem
what could be causing my crx with b16 to backfire when shifting gears any suggestions
Old Nov 19, 2008 | 04:10 PM
I CRX I's Avatar
is your ecu chipped? if not, maybe bad 02?
Old Nov 19, 2008 | 05:11 PM
dschenke's Avatar
when a car is runnin rich it backfires because extra fuel getin into the exhaust an from the exhaust being so hot it ignites the fuel causin a backfire
check ur fuel pressure n wat injectors are u using
Old Nov 20, 2008 | 04:11 PM
socal-crx's Avatar
the motor is pretty much stock with skunk2 stage 1 cams, intake and exhaust. problem started when I swapped the header for stock manifold and the stock p30 ecu
Old Nov 21, 2008 | 09:01 PM
dschenke's Avatar
ur ecu is not throwin any codes is it?
Old Nov 22, 2008 | 11:34 AM
socal-crx's Avatar
nope not throwing any codes
Old Nov 22, 2008 | 12:53 PM
0ne-Cam's Avatar
how about when u swaped in the aftermarket cams.. did u time it correct? check the timing maybe its off by a tooth. loosen up ur dizzy retard it or set it ahead. i had a similar problem on my h22 when i shift thru gears around 4 to 5k rpm it backfired like crazy, found out it was one of the valves, but that might not be ur case
Old Nov 22, 2008 | 04:28 PM
dschenke's Avatar
wat u mean one ur valves?
explain
Old Nov 22, 2008 | 07:29 PM
exz0n-.-'s Avatar
backfiring is tight, quit whining!
Old Nov 22, 2008 | 08:33 PM
NATEDEEZY's Avatar
check your dizzy timing, you might be running rich also, and if i were you i would get some cam gears and degree them could be that too
Old Nov 23, 2008 | 09:33 AM
0ne-Cam's Avatar
explain
i meant to say i had bent valves
Old Nov 28, 2008 | 09:26 AM
socal-crx's Avatar
cool thanx for the info i'll check the timing
spoolinNpullin
16
Jun 5, 2009 07:25 AM
JDM_is_overrated
Aug 15, 2008 03:04 PM
whiteJDMdc2
Mar 16, 2005 11:59 AM
russian_racer
Apr 3, 2003 03:16 PM
90civichbsi
28
Sep 19, 2002 08:08 PM
