removing sound deadening leftovers
Old Nov 19, 2008 | 01:14 PM
petwhookie's Avatar
Icon2 removing sound deadening leftovers
I took out all of the sound deadening in my car but there is a lot of leftovers on the car still. It's just small little chunks throughout the car, I can take a chisel and remove it but this process is EXTREMLY slow. What other methods are there?
This was before I vacuumed the little peices out but you can still see those "leftovers"
Old Nov 19, 2008 | 01:40 PM
phatrick2332's Avatar
Don't you just love trying to get the tar/glue off around the drain plugs? I'm in the same process right now and its a pain in the ***.
Bump, since our new search function is horrible.
Old Nov 19, 2008 | 01:43 PM
petwhookie's Avatar
Thanks for the bump, I couldn't find anything too helpful.
And yes! those plugs are a bitch
Old Nov 19, 2008 | 01:45 PM
dc4_wHORE's Avatar
Soldering Iron Wizardry
i'm using goo gone and a chisel and it's taking forever......... bump
Old Nov 19, 2008 | 04:24 PM
biggoofy's Avatar
air chisel lol it works great for me i just need to finish
Old Nov 19, 2008 | 04:31 PM
majinsoftware's Avatar
paint stripper then it just wipes off, But be sure to paint the exposed metal the same day other wise it gets a bit of surface rust.
Old Nov 19, 2008 | 04:59 PM
petwhookie's Avatar
dang, anyway to avoid that? im trying to not paint the car right now
Old Nov 19, 2008 | 05:05 PM
SoTexDC2's Avatar
Primer...
Old Nov 19, 2008 | 06:17 PM
biggoofy's Avatar
i ll have to try this will aircraft stipper work
Old Nov 19, 2008 | 06:25 PM
VTEC_PRODUCTION's Avatar
**** NO! use acetone...it will take off a light coat of paint but it shouldnt STRIP it like you DONT want to do...
Old Nov 19, 2008 | 06:31 PM
biggoofy's Avatar
awesome thx
Old Nov 19, 2008 | 06:54 PM
petwhookie's Avatar
I just put soaked Goo Gone for about 5 hours on the leftover parts and I scrapped it off easily. Its too late right now and my neighbors will complain if I try right now. I guess I will have to give the interior a temp coat of primer cause the Goo Gone kills the paint coating?
Old Nov 19, 2008 | 06:59 PM
SlammedDC2's Avatar
Semper Fidelis
I removed all the sound deadening from my trunk in about 10 minutes. Drop some dry ice on it, let it sit for a few minutes and pick at it with a scaper. Takes it off in no time. Just please please please wear thick gloves preferably leather as the dry ice will burn you.
I dropped the ice on for a few minutes then rubbed the deadening with the ice and it came off no problem.
Hope this helps.
Old Nov 19, 2008 | 08:25 PM
steveo135's Avatar
Hope this helps.
x2 after the dry ice has been on it you can just bang it with a hammer and it'll break right off
Old Nov 20, 2008 | 04:51 AM
KeithsDAteg's Avatar
Put this stuff on it... Let it soak for a min, wipe excess up, then wire wheel the **** out of it!!
Good luck
Old Nov 23, 2008 | 03:07 PM
petwhookie's Avatar
^ I Used the 3M adhesive remover and it did the job. It stunk but worked. Thanks for the advise. Now its time to paint it.
Old Dec 16, 2016 | 10:16 AM
Sleeper_Integra's Avatar
Default Re: removing sound deadening leftovers
I know this thread is dead but did you use a wire wheel? Think a hard scrubber will do the trick?
Old Dec 18, 2016 | 02:33 PM
MotorMouth93's Avatar
10 Year Member
Best way I've seen to do this is buy a bunch of dry ice, crush it up, and dump it on the sound deadening. Once it gets cold it just pops right off, and the bits that are left you can tap with a hammer and they'll come off easily.
Old Dec 21, 2016 | 12:39 PM
killett's Avatar
Wow. I can't believe I never thought of this. I'll have to give it a shot- I've got two cars that this might do the trick for!
Agito
Paint and Body
Mar 29, 2008 01:56 AM
dragonfly2k3
Jan 3, 2008 08:45 PM
O16581724 5 2 5
Paint and Body
May 1, 2007 11:18 PM
Alibi86
Aug 12, 2005 10:48 AM
Nghtmar911
Mar 28, 2004 03:28 PM
