The Hood?
If you don't have anything productive to say keep your thoughts to yourself.
OP no a scoop isn't going to help you. As for weight reduction and track times. Every 100 pounds you loose, you gain 1/10th of a second. Loose 500lbs gain half a second.
pretty much all there is to it. the only performance gain is the weight reduction and it may lower the under the hood temp a little
