any one use a tilton hydro t/o bearing?
Old Nov 18, 2008 | 05:42 PM
got wide's Avatar
Default any one use a tilton hydro t/o bearing?
is anyone using or know about these tilton hydraulic through out bearings? do they reduce pedal effort significantly? how do they mount to the trans? i cant seem to find much info on them.
are the tilton twin discs much stiffer than say an act single disc w/ extreme pressure plate?
Old Nov 19, 2008 | 12:32 AM
N.Y.C.E.'s Avatar
the tilton hydro bearing gave us alot of trouble, 2 units broke along with 2 clutches(twins). try spec or competition clutch with a stock tb less trouble!
Old Nov 19, 2008 | 02:00 AM
redboost10's Avatar
i have not had one issue with the tilton throw out bearing. the pedal feels just like a stock clutch to me.
not alot of people like this bearing, but you just gotta set up the clutch pedal right
Old Nov 19, 2008 | 02:48 AM
nitroice40's Avatar
it takes some time to set it up. You have to do it right or it will give you problems. It kinda sucks for street driving its a on or off clutch very hard to slip
Old Nov 19, 2008 | 07:17 AM
PeakBoost's Avatar
B*A*N*N*E*D
I run one in our EVO8 and the pedal stop must be setup so that you don't over throw the HRB. If not, you can cause either damage to the HRB or even worse, the crank thrust bearings.
HTH
-Ken
Old Nov 19, 2008 | 09:37 AM
tuan_turbo_dc4's Avatar
I run one in my car with a tilton clutch and a tilton master cylinder kit, and it feels like stock. I like it way better than using the stock clutch master cylinder.
The bearing is placed inside the transmission housing, it goes over the input shaft and a couple of stainless braided lines are connected to the bearing going thru the front of the transmission where the stock fork use to be, one of the lines feeds the fluid to the bearing and the other line is used to bleed the lines.
I have a brand new unit with the stainless steel lines for sale if you are interested. And I also I have a tilton 75-series master cylinder kit to go along with it.
Old Nov 19, 2008 | 01:54 PM
redboost10's Avatar
same setup as me and i couldnt agree more. i have read in some old posts that if you dont run the whole package, it tends to not feel the same and not as comfortable.
Old Nov 19, 2008 | 01:59 PM
B18C1CYA's Avatar
so then the tilton throw out bearing works better with the tilton 75 master ? and do you still need the peddle stop or no ?
Old Nov 19, 2008 | 02:18 PM
redboost10's Avatar
from what ive gathered from reading on ht, the tilton bearing works better with the tilton master cylinder due to the larger bore size than the oem clutch master cylinder.
also the rod is somewhat adjustable on the tilton master cylinder.
its not that hard to set up a pedal stop.
Old Nov 22, 2008 | 09:01 AM
got wide's Avatar
is it kinda similar to the feel of the hydro tb in the 350z, g35, g37 for anyone whos driven one?
Old Nov 24, 2008 | 05:50 PM
got wide's Avatar
i understand that it goes over the input shaft and what the lines are but what holds it in place in the bell housing?
Old Nov 24, 2008 | 09:22 PM
redboost10's Avatar
the pressure that it has against the pressure plate. its the same thing as the oem throwout bearing, that is just sitting on the input shaft as well, basically.
Old Nov 25, 2008 | 04:52 PM
got wide's Avatar
but the stock tb is held by the release fork. what would hold the tilton when the fork is removed?
any one have a pic of it installed? i cant seem to visualize it
Old Nov 25, 2008 | 04:59 PM
redboost10's Avatar
there is a gasket o-ring towards the back of the bearing that tends to keep it tight around the input shaft. dont worry it wont go anywhere.
[IMG]http://www.tiltonracing.com/incs/ima...?picture=d0066[/IMG]
i have no idea how to post pictures on this new ht, but there you go. cant see the gasket but it around the inside diameter of the bearing.
Old Nov 25, 2008 | 05:08 PM
got wide's Avatar
but the input shaft is spinning and the bearing would have to be held still right?
Old Nov 25, 2008 | 05:24 PM
redboost10's Avatar
the bearing slides all the way to the back of the input shaft so it sits flush with the bellhousing
Old Nov 25, 2008 | 05:35 PM
got wide's Avatar
right i understand that but what keeps the "body" of the tilton from spinning? like if the bearing seized what would keep it from spinning and ripping out the stainless hoses
Old Nov 25, 2008 | 05:49 PM
redboost10's Avatar
that whole section of the input shaft that sticks out of the bellhousing does not spin, only the last 4 inches or so that is splined. so basically where the bearing sits on the input shaft is way back against the bellhousing and it stays put due to the gasket, its actually a tight fit around the input shaft due to that o-ring gasket. only the face of the bearing sping which is riding on the pressure plate. its hard to explain, im sorry.
Old Nov 27, 2008 | 07:24 PM
got wide's Avatar
i think i understand what your talking about i just figured it would have to be bolted to something. ive seen some bad things come from seized bearings.
EG_SINZ
Transmission & Drivetrain
Mar 7, 2016 12:46 PM
My87rex
Feb 12, 2006 07:19 AM
Hyaboosta
Mar 17, 2005 07:24 AM
mr_mbuna
Dec 4, 2002 04:04 AM
unFOB4U
17
Oct 24, 2001 09:21 AM
