weird clicking noise...
i took off my head on my GSR, replaced rocker arms, went back to stock, did the usual head-rebuilding things (i.e. recut valves, seatvalves etc) and my car started up just fine. had a small exhaust leak from re-using the old header gasket, as i expected, but as the car idles about 5+ minutes, and starts to get hot, it has some NASTY clicking sounds coming from what sounds like the front of the head (exhaust side).
i did a valve adjustment also, but i left the exhaust side at about .010" (normally .008"-.007"), and intake at .008" (normally .007"-.006"). when i rev it, i cant hear it clicking, but when it idles, i hear it clicking just at random.
earlier it was continous, '.... click click...... click click..... click click'
i checked a few things, turned it on, and its doing it at random now, 'click.... click ..... clickclick..... CLICK..... click ..click'.
anyone got any suggestions?
oil came out good... dirty, but good.
and i didnt re-surface it this time, because last head gasket i put on (2 weeks before this one) was taken off because of bad problems i was having with the car. when turned on, it wouldnt idle, wouldnt rev, wouldnt run, northing. so i pulled the head, and had to replace 2-3 valves. so i figured head was still straight since the car was only on for about 10 minutes before.
valve lash is good, but ill check it again, and set it as close as i can to spec.
Lost motion assembly.
They are little spring/hydrolic cussions that sit under the vtec rockers. They stop them from flaping around while the vtec pin isnt locked in. The hydrolic(old style) ones wear out every 50,000ks or atleast they did for me. Then the tapping sound would come back. Spring(new style) ones seem to last alot longer, never worn a set out.
Have a read of this,
http://www.g2ic.com/forums/showthread.php?p=1888923
oh, those! i always refered to them as 'lifter' cause i didnt know the proper name lol.
yeah, theyre hydrolic. is there any way to check them? whatever it is didnt start clicking till after i pulled my head the second time. a few fell out, and i lubed them up, and stuffed them back in, so maybe i put them in incorrectly, or something.
