My Ls/Vtec isn't starting. Need Help
Had a Ls motor running fine but the timing belt looked like it was ready to give out on me. Had a b16 head and complete ls/v golden eagle kit layin aroung. To make a long story short. I did the headswap. Using a chipped ecu that worked perfectly fine on an old car i had. Timing is on point. All my Grounds are straight. Fuel is gettin up to the rail. Cranks, but just wont fire up. i put the obd2 p75 in just to see if the computer was the problem still..no firing up.
Need some advice people..thanks.
check your grounds, I had a problem starting my car a long time ago, it would crank but never turned. Finally I checked my ground from the chassis to the tranny, it was loose so i tighten it. Went to turn it over and voila, it started. Hope that helped.
i checked all grounds it wasn't that.. i gotta do a spark check and hope for the best.. thanks for the help.. if anyone has any other pointers post up.. please.. thanks
