Clutch pedal adjustment
Old Nov 18, 2008 | 10:22 AM
Kyle244R948's Avatar
Default Clutch pedal adjustment
I just installed my new clutch and I think my clutch pedal needs to be adjusted. The clutch doesnt disengage until the very top of letting it out. I was wondering if it is just the clutch pedal that needs to be adjusted or is it something else? If it is just the clutch pedal, how hard is it to adjust?
Thanks
Old Nov 18, 2008 | 11:36 AM
vxhatched's Avatar
A new Clutch is going to grab really good first time installed. Most of the time just installing a clutch, the petal adjustment from the factory will be perfectly fine, if not adjust to your likings. What stage is the clutch or is it just stock?
Old Nov 18, 2008 | 11:45 AM
Its stock clutch. The car doesnt move until I am almost at the top of being off the pedal. It doesnt grab as soon as the pedal comes off the floor or anywheres close to it. Could this be a problem? Could it be my clutch fluid?
Thanks
Old Nov 18, 2008 | 01:03 PM
2001TypeR's Avatar
Im also wondering about the exact same thing with the same situation.
bump
Old Nov 18, 2008 | 03:34 PM
EARLdaSQUIRREL's Avatar
official honda whore
did you blead the clutch properly, also you can adjust the rod on the clutch master cylinder if you really need to,
Old Nov 19, 2008 | 03:22 AM
I havent bled it since I installed the th clutch. Wasnt sure if I had to or not. How hard is it to adjust the rod on the master cylinder?
Old Nov 19, 2008 | 11:38 AM
2001TypeR's Avatar
bump
Old Nov 20, 2008 | 04:31 AM
anyone, anyone?
Old Nov 20, 2008 | 04:44 AM
mach0's Avatar
try to bleed the clutch first.Then see where the clutch grabs
Old Nov 20, 2008 | 04:49 AM
Will do this weekend, and let you know. thanks
Old Nov 25, 2008 | 11:40 AM
kay_animation's Avatar
Here ya go if you need to adjust it:
https://honda-tech.com/forums/showth...=clutch+adjust
I had to do the same thing when I put in a new clutch MC but hopefully you don't have to do this just because of a new clutch. Unless you just personally want a different feel.
Tip I would have is park on a slight hill so you can test and don't tighten the bolt till you test the feel and like it. Might take a few tries.
Old Nov 26, 2008 | 01:25 AM
2001TypeR's Avatar
Thank you, this is what i wanted to see.
Dre_559
May 28, 2009 08:23 PM
Kermit EK
Jan 29, 2003 03:02 PM
Steve
Jul 23, 2001 01:42 PM
