Fuel pump relay??????????please help
Old Nov 18, 2008 | 07:48 AM
4banger1986's Avatar
Default Fuel pump relay??????????please help
Hello my car is a 1997 GS my fuel pump is not getting power. Everything in the car is working but the Pump . I hard wired it and it does work , has anyone had this issue or can anyone help me?
Old Nov 18, 2008 | 07:54 AM
HitF8's Avatar
main fuel relay
Old Nov 18, 2008 | 08:03 AM
Thats what i was thinking but i was wasnt sure because everything esle in the car seems to be working fine
Old Nov 18, 2008 | 08:12 AM
Does anyone know if i can use a main relay off any other honda/acura?
Old Nov 18, 2008 | 09:22 AM
anyone else had this issue?
Old Nov 18, 2008 | 12:35 PM
bump
Old Nov 20, 2008 | 11:23 AM
i need help bump
Old Nov 20, 2008 | 12:51 PM
efvader's Avatar
just call your local honda/acura dealer and ask for a main relay they are like 60 bucks.
p/n 39400-s10-003
Old Nov 20, 2008 | 03:12 PM
fonkernuckle's Avatar
You can also unplug the main relay and using a paper clip connect the two pins on the harness plug that provide power to the fuel pump to confirm that its your relay thats bad, this is per helms if you can't get one then pm me and I'll go to the garage and look up what pins. When I tested mine I had my fuel line (going to the fuel rail) disconnected and in a bottle and sure enough once pins were shorted and power on out came the fuel
jarol220
Dec 9, 2021 10:10 AM
ksbenjamin44
Jun 25, 2009 05:22 PM
si 1
Dec 21, 2005 11:03 AM
bigbacon2
Jul 31, 2005 05:34 PM
